Special connector?
Old Mar 13, 2020 | 09:42 AM
ynot321AB1's Avatar
ynot321AB1
Special connector?
Am about to start wiring a '50 Ford F-1 and in looking at the connections on the gauges, specifically the amp gauge, is there a special type connector for this gauge? All of the others have a screw to mount a wire to but as seen in the pics the amp gauge has some other type of connector. Thanks for any help received in advance.
Connection for amp gaugeated.
Old Mar 13, 2020 | 09:54 AM
Mixer man's Avatar
Mixer man
There is no physical connection to the ammeter. The ammeter uses the Hall Effect to measure current (not voltage). Simply run the insulated wire through the loop in the correct direction for positive or negative ground systems.
http://hyperphysics.phy-astr.gsu.edu...etic/Hall.html
Nerd alert: Difference between a gauge and a meter (just for clarification). For automotive purposes a meter measures the rateat which something occurs (ammeter, speedometer), whereas a gauge quantifies a standard, as in pressure, distance, etc.
Old Mar 13, 2020 | 10:15 AM
ynot321AB1's Avatar
ynot321AB1
Please to excuse the stupid questions, but could you further explain? Do I just loop a 12 gauge wire through the loop and back to the breaker and how do I determine which direction to put the wire for a positive ground
Old Mar 13, 2020 | 10:33 AM
Mixer man's Avatar
Mixer man
Originally Posted by ynot321AB1
................ but could you further explain? Do I just loop a 12 gauge wire through the loop and back to the breaker and how do I determine which direction to put the wire for a positive ground
In the illustration the ammeter is referred to as the "battery charge indicator". Just note the direction of the yellow wire from the circuit breaker to the battery terminal on the starter relay (do not attempt to loop the wire, just pass straight through one time). This is correct for a positive ground system. For a negative ground system simply reverse the direction of the yellow wire.
Old Mar 14, 2020 | 10:01 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Is there a recommended gauge of wire for this?
Old Mar 14, 2020 | 10:30 AM
ynot321AB1's Avatar
ynot321AB1
Don't know
I am using 12 gauge wire throughout the wiring process but do not know if there is a specific gauge for that purpose.
Old Mar 14, 2020 | 10:34 AM
bjmayberry2
The reason I ask is because the old wire that went through the AMP meter was fairly large. Read this from classic Instruments:
https://www.classicinstruments.com/u...n%20012313.pdf
Old Mar 14, 2020 | 10:43 AM
Mixer man's Avatar
Mixer man
Yes, and it should be capable of handling the full capacity of the generator or alternator being used (right column). The pickup loop on the ammeter is capable of handling up to AWG 6 insulated wire.
Old Mar 14, 2020 | 10:53 AM
Mixer man's Avatar
Mixer man
That type of meter is direct reading and requires a shunt. It is internally shunted. Externally shunted meters can go much higher. The Ford ammeter operates on an entirely different principle where the actual current does NOT pass through the meter.
If you've ever seen a meter like this, it operates on the same Hall Effect principle as the Ford ammeter (never mind the probes).
Old Mar 14, 2020 | 11:04 AM
Mixer man's Avatar
Mixer man
I am using 12 gauge wire throughout the wiring process.
Totally unnecessary, and extreme overkill, but won't hurt anything. May look very bulky though.
Old Mar 14, 2020 | 01:46 PM
49fordv8f4's Avatar
49fordv8f4
The wire thru the ammeter should be 10ga for 6V. Headlights and horn are 12ga, most of the rest of the wire is 14ga. The routing direction thru the ammeter shown on the diagram may not be correct, I routed mine opposite that for 12V neg ground and my ammeter reads backwards. I will just have to leave it that way as I can't work under the dash to change it.
Mark
Old Mar 14, 2020 | 02:07 PM
bjmayberry2
Mark
If you bring it to the Ozark Mountain Run, maybe we could fix that.
Old Mar 14, 2020 | 04:13 PM
oneye's Avatar
oneye
Tip of the hat(s) to Mixer Man for his always solid explanations
when it comes to the electrical questions....
Old Mar 14, 2020 | 04:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It will also make it hard to fit the needed wires thru the bulkhead connector.
Old Mar 14, 2020 | 07:58 PM
artscott61's Avatar
artscott61
Veteran: Navy
I learned something on this one. Thanks Guys.
