AOD compatibility
Old Mar 12, 2020 | 05:48 PM
SjoDon's Avatar
SjoDon
AOD compatibility
I have a line on a complete AOD transmission (driveshaft to block) and just found out it is for a 4wd. Will the trans or any other items work on a 2wd??
Old Mar 12, 2020 | 06:47 PM
53deere's Avatar
53deere
I'm pretty sure the trans will need to come apart to install the correct 2wd output shaft to work with the 2wd tail housing. I'd recommend looking for a 2wd drive trans. It also needs to match the engine unless you are planning an adapter.
Old Mar 12, 2020 | 07:25 PM
SjoDon's Avatar
SjoDon
I had a feeling it wouldn't work.
Thanks
blueblood73
1978 - 1996 Big Bronco
Aug 1, 2017 01:33 PM
jetjr1865
Nevada Chapter
Mar 27, 2011 07:34 AM
smaybery
Feb 24, 2008 11:00 PM
makemeknowit
Oct 2, 2003 05:30 PM
