headers
Old Jan 31, 2001 | 10:19 AM
cgl's Avatar
cgl
headers
Old Feb 15, 2001 | 12:38 AM
rayvin_'s Avatar
rayvin_
headers
I have an 89' f150 I6 4.9l(300)truck and I so despritly want to get some performance headers for it, but the problem is that everywhere I look, be it online or in mags, I can not find one listing of a company that produces these types of headers. If anyone where I could get these, and how much $, I would appreciate it greatly. I am tired of being stuck at something like 165hp(Flowmasters).
Old Feb 15, 2001 | 05:11 PM
red rider's Avatar
red rider
headers
Clifford performance---use search engine
Old Feb 15, 2001 | 07:22 PM
otto's Avatar
otto
headers
http://www.cliffordperformance.com sells split headers so you can have true duals and better performance
Old Feb 15, 2001 | 08:03 PM
KevinT's Avatar
KevinT
headers
Rayvin:
The exhaust isn't what is holding your performance down, the stock fuel injectors on your truck can only handle providing enough fuel for 150.2 hp, the only way to get around this is to buy new injectors, stock is 14# an hour...mustangs and explorers with v8's for example have 19# an hour units, those should do nicely, on my truck I installed 20~something# an hour units (they arent marked, just color coded, you should be looking for white or yellow ones, im not sure) Getting to the fuel rail on these EFI motors is a PITA, have to take off the upper intake and the wire harness on the injectors...oh man! I broke the connectors on 5 of the 8 plugs on my injectors, have to lift 2 tabs one each side and pull at the same time, after teaching the neighbors kids a few new words I finnally just stuck a flathead screwdriver on one side, thumbnail on the other tab and yanked up on the screwdriver, poped almost everytime...I just hope they dont rattle loose and cause me to be running on like 2 cylinders or something! Then after doing this the fuel pressure regulator wasn't providing enough fuel for my setup, so I had to get a adjustable unit and play with it a bit, the way I adjusted it is since I have a 5-speed...when it was lean and I engine braked by downshifting I could hear a REALLY cool popping sound out of the exhaust, but once I got it set right I could definatly feel the difference. Good luck on the headers, but my 2cents is you need new injectors.
1995 F-150XL SC/SB
http://members.sounddomain.com/blind
5-Star Rated F-150 (Big Stereo)
Old Feb 16, 2001 | 09:55 AM
oldblue18's Avatar
oldblue18
headers
Hedman Headers also makes a dual flange header for a 300-6. In my P.A.W. book, they sell for $129.
Old Feb 22, 2001 | 01:11 PM
amadorjon's Avatar
amadorjon
headers
Jegs also sells the headman headers for $129.Clifford Performance not only sells headers but many usable performance parts for these engines.Ii talked to them and they said the first mod to do to the 300 is the header cause the exaust is very restricting on these trucks.Good luck.
Jon
