built 9" can take it?
Old Oct 14, 2003 | 09:12 PM
nevrenufhp's Avatar
nevrenufhp
This one is kind of tough to guesstimate for me:
'72 F-100 with a non-GM engine that really cranks out some power(estimated 800 pounds of tork). How much power could a 9" take before I should consider a Dana 60 or 70? Even if equipped with Currie or Moser 35spl. shafts, a Detroit, and gusseting.
Old Oct 14, 2003 | 10:05 PM
fordeverpower's Avatar
fordeverpower
build it up and hope for the best. What kinda motor you got turning out 800ftlbs of torque. I would beef it up and run it. The trans, driveshaft and other components will need upgraded just as well but i'm sure you already know that.
Old Oct 14, 2003 | 10:08 PM
fordeverpower
don't tell me that 360 is making 800 ftlbs of torque because i find that very hard to believe.
Old Oct 15, 2003 | 09:42 PM
DW2455's Avatar
DW2455
if you do infact have that much power, you need to upgrade the carrier asm. and the axles. DW
Old Oct 16, 2003 | 02:07 PM
TorqueKing's Avatar
TorqueKing
3 words:
Driveshaft Safety Loop!
Old Oct 17, 2003 | 08:35 AM
Hired Gun's Avatar
Hired Gun
A good aftermarket case, pinion support. (read Mark Williams) and 40 spline axles and you will never fail that 9". Dana axles are a pain to set up and they are not that much stronger. I had a trick Dana 60 that was built by Mark Williams with 40 spline axles in my *****'s Jeep and I blew the gears out of it a couple times with a small block. Of course a 40 pound flywheel and metalic clutch leaving at 8600+ on 20" paddle tires might have had something to do with it.
