Bronco II Ford Bronco II
88 Bronco 2 project
Old Mar 10, 2020 | 11:41 AM
rjdj1186's Avatar
rjdj1186
88 Bronco 2 project
Hey FTE Bronco 2 guru's, I am isually on the 7.3 PSD forum but am trying to help my buddy with his 88 bronco 2. I originally posted in the big bronco forum by mistake. Got some good advice, but only from one guy, and it doesn't seem to have done the trick. Hoping some more heads can come up with something...
He got this old not running bronco 2 2wd and another 4wd without a motor. He plans to put the 4x4 stuff in the 2wd, if he can get it running. He has been at it for weeks, throwing parts at it and getting nowhere.
He is not getting spark unless he unplugs the pcm or spout connector. He has had new Icm three times, new pcm twice, because everyone tells him that must be it. But it is not. New rotor, cap, coil, tested relays, checked grounds, traced wires...
Anybody out there run in to anything like that before? He is currently contemplating the merits of using it for target practice, which is a shame as he was so excited about the project a few weeks ago.
I appreciate your help.
Old Apr 27, 2020 | 07:43 AM
Gazious's Avatar
Gazious
Timing
Hello,
First off, I need a little more information, like what years are both trucks, which engines were originally in both trucks??
I will presume they are the same year and had the same engine:
since ​​​it does start that's good ,wouldv it sounds like the timing is off. Get a good idea of where the distributor should be but leave the distributor loose enough to be able to adjust it while running (not so loose that the hold down piece falls off). Then disconnect the pigtail or spout cap and start the engine with a timing light on. 12° btdc comes to mind but it is well know, in the manual and on the sticker under the hood. Set the base timing, turn off the engine, reconnect the spout plug cap.
Old May 2, 2020 | 01:37 PM
rjdj1186's Avatar
rjdj1186
Hey gazious, thanks for responding. I had originally posted in the wrong bronco forum, so reposted here. Got some good advice on the other thread, even though it was in the wrong place, and got it figured out. Turns out, somewhere along the lines someone had done some creative wiring at the pcm harness just this side of the firewall. Got that fixed up and she fired up.
I appreciate you responding. Sorry I didn't think to update this thread.
Old Jun 12, 2020 | 07:07 PM
viking1965's Avatar
viking1965
4wd High
V-8 swap turn your B2 into a beast did one years back that truck was a blast
Johnny Mayday
1978 - 1996 Big Bronco
Jul 2, 2018 02:55 PM
revodell
Bronco II
Nov 17, 2017 08:16 AM
83fordf150
38
Nov 26, 2015 05:03 PM
christop43
Mar 12, 2004 10:22 AM
mikefraz01
Jul 3, 2003 08:26 PM
