dash knobs
Old Mar 9, 2020 | 07:58 PM
smd123's Avatar
smd123
Trailering
dash *****
Has anyone replaced their dash *****? I see sites selling them, but I wonder how they install since it looks like most of them are molded on? Especially the vent windows, choke, etc.
Old Mar 10, 2020 | 06:48 PM
spurredon's Avatar
spurredon
Many for sale come with a set screw.
Old Mar 10, 2020 | 07:38 PM
Red60's Avatar
Red60
So do they expect the buyer to break off the old ***** without damaging the other components?
BMC
Old Mar 10, 2020 | 09:14 PM
smd123's Avatar
smd123
Trailering
It seems like they would be prone to rattling loose. Does anyone have any feedback on the new *****? I'm trying to decide if I should upgrade... my originals are pretty well worn.
Old Mar 11, 2020 | 07:39 PM
spurredon's Avatar
spurredon
I had a couple that were crumbling off, the new set screw types seem to be alright.
Old Mar 12, 2020 | 04:52 PM
Red60's Avatar
Red60
how did you remove the old *****? Do they come off reasonably?
BMC
Old Mar 12, 2020 | 07:13 PM
spurredon's Avatar
spurredon
The shaft is knurled inside of the molded ones. I cut them off somehow but I can't recall. I do remember it took a little while.
Old Mar 16, 2020 | 12:02 PM
smd123's Avatar
smd123
Trailering
So I just received a choke **** from LMC. It has a threaded brass boss inside that looks like a #10-32. I had a spare choke cable so I broke the molded **** off. The metal that's left is too large to run a die over it to get a #10-32 thead.
And of course the **** doesn't have any instructions, so I'm puzzling over this one.
Old Mar 16, 2020 | 12:41 PM
Red60's Avatar
Red60
Does the **** also have a setscrew on the side to lock it down?
Old Mar 16, 2020 | 12:48 PM
smd123's Avatar
smd123
Trailering
Nope, no set screw.
The heater and wiper ***** have set screws, but they do not fit over the metal rod for the choke.
Old Apr 15, 2020 | 03:01 PM
smd123's Avatar
smd123
Trailering
Anyone else have any experience on these *****? I have shelved this until I can figure out how to get these things on. I probably should just call LMC and return them, but it seems like there must be a way.
Old Apr 15, 2020 | 11:25 PM
Red60's Avatar
Red60
Am I correct in thinking all ***** fit and function correctly except the choke? What is the shaft diameter of the choke rod? Did you try to thread a 10-32 bolt into the **** to verify its sizing? (Could take it to a hardware store and find correct size threads if necessary). Once you know the size differential its a good start point. Forum people can measure their choke rods to confirm also. Just ideas but calling LMC is likely a good idea.
BMC
Old Apr 16, 2020 | 10:36 AM
spurredon's Avatar
spurredon
Since it has brass inside, could you drill it out to the choke rod size and put a set screw on it? Also put a dimple in the choke rod for the set screw to catch.
Old Apr 23, 2020 | 11:49 PM
rarely's Avatar
rarely
there should be a full switch kit- honestly there should be a entire switch kit- the closest we get is a full wiring harness the happens to have the switches- as for *****, ha . ( i want to make a uk **** joke here )
spoolen&smoken
6.4L Power Stroke Diesel
Apr 12, 2013 11:08 AM
