F1 49 speedometer problem
Old Mar 8, 2020 | 03:03 PM
Litjon's Avatar
Litjon
  • Ford 49 f1 truck. I just purchased my 49 Ford f1 truck. The speedometer cable was missing. So I purchased one from Midwest Early Ford. Greased it with white lithium and hooked it up. As I am in Ohio I tested the speedometer my putting the rear wheels on jacks and it looked like it was working fine. I finally had a nice day to take it for a drive. The speedometer didn't move. Both ends of the cable are still tight. Any thoughts? Thanks for the help!
Old Mar 8, 2020 | 06:12 PM
FortyNiner's Avatar
FortyNiner
So, the speedo needle moved during the jack stand test?
Before you screwed on the caps, did you seat the cable ends in their receivers?
Old Mar 8, 2020 | 07:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Grease is pretty heavy for that, especially in cold weather. Usually either light 10w oil or graphite (like used on locks) is called for.
Old Mar 8, 2020 | 08:21 PM
Litjon's Avatar
Litjon
I was able to screw the caps down on both ends after making sure the inner cable was inserted into the hole. Was there a trick to this or something to watch out for? As far as the lithium grease I applied a thin coating wearing a latex glove. After reading several threads the main recommendations seemed white lithium grease and not to overdo it
Old Mar 8, 2020 | 08:37 PM
FortyNiner's Avatar
FortyNiner
The insertion isn't tricky it just needs a bit of focus. I'm sure you did it correctly.
Back to my question: Did the needle move on the speedo during the test run?
gogoat
Feb 29, 2016 08:23 PM
Cougar54
May 12, 2015 08:44 AM
iwanaflattie
May 6, 2011 08:38 PM
polarspeed
Feb 8, 2010 08:24 PM
