Heated seats
Old Mar 7, 2020 | 03:42 PM
kaw1000r's Avatar
kaw1000r
Heated seats
Wiring up heated seats, so I found a hot wire that is only hot when running and connected to gr/red wire on console switch and ran wires to the seats from yel/blu & gry/blu but nothing happens when I push button on console. Tried wiring hot straight to each seat wire and still nothing. I did run a ground for the blk/wh wire off of console switch also. Any ideas on what I need to do? t/u
Old Mar 8, 2020 | 10:02 AM
shorod's Avatar
shorod
What year Explorer are the seats from? Have you checked for continuity through the heating elements? Are the console switches from the same year Explorer?
-Rod
Old Mar 8, 2020 | 10:23 AM
kaw1000r's Avatar
kaw1000r
Diagram
-Rod
2008 Explorer seats, no I haven't chk continuity but will today and yes switch from same vehicle. I did see where 1 wire is for illumination that I don't have connected.
Old Mar 9, 2020 | 08:05 PM
shorod's Avatar
shorod
The logic that controls the heated seat relays is apparently powered via the Gray/Orange wire at connector terminal 9, so you'll need that one powered as well for the switch to work. It appears you need power to terminals 3, 5, and 9 and ground on terminal 10 for the switch and relays to work. If you want the LED indicators to work you'll also need ground on terminal 6 as well.
You'll want to make sure the ground is good for the heating elements as well after you check for continuity through the heating elements. I say "continuity" but you probably want to instead check for ohms of resistance. I'm unsure how many ohms of resistance you should have through the elements, probably something less than 10 ohms. But the amount of resistance needed for a meter to beep continuity can vary from model to model.
-Rod
Old Mar 10, 2020 | 11:17 AM
kaw1000r's Avatar
kaw1000r
Heated seats working
-Rod
T/u I was wondering about 6 & 9. Everything is working, just need to clear airbag light on dash. Have to make sure wires are connected under seat. Have to go back and look at plug diagram and try my scanner to clear before making appointment with Ford...
Old Mar 20, 2020 | 12:33 PM
dremtofford's Avatar
dremtofford
did they have heated seats in a 91 eddie?
Old Mar 20, 2020 | 06:29 PM
kaw1000r's Avatar
kaw1000r
Nope
Sport trac wasn't made in "91"... So that would be a no
Lil_e1
Garage & Workshop
Jan 10, 2016 08:03 AM
Muddbugn1
Jan 11, 2014 09:45 PM
slcdzl
Aug 19, 2009 03:58 AM
LSAtexan4x4
Jun 10, 2008 04:49 PM
timcommon
Jan 7, 2008 01:34 AM
