Fuel Pump voltage
Old Mar 6, 2020 | 03:44 PM
maxsams9's Avatar
maxsams9
Fuel Pump voltage
Hello,
1986 F150 EFI
What is the voltage at the frame rail pump supposed to be?
Thank you.
Old Mar 6, 2020 | 08:12 PM
diggerrigger's Avatar
diggerrigger
Main pump is always 12 volts. The tank pumps do run on lower voltage. The tank pumps use 12 volts while the engine is being started, cranking.
Old Mar 8, 2020 | 05:40 PM
maxsams9's Avatar
maxsams9
Thank you.
I have 4.5-5.0v at that pump. 12 coming out of new relay and pigtal for relay. Fuel pressure is 35 psi at fuel rail. Could be the reason for hard cold starts?
Old Mar 9, 2020 | 09:25 PM
diggerrigger
Originally Posted by maxsams9
Thank you.
I'll double check that voltage tomorrow. I think 35 PSI shouldn't be a problem. I'll check my notes on the pressure. I just ran a fuel pressure test on my truck a few months ago.
My truck is a good running (and starting) '86 F150 5 EFI
Old Mar 10, 2020 | 08:40 AM
diggerrigger
Thank you.
My notes show 35 psi looks good. Wiring diagram shows 12v to main pump.
sheevesakatyler
May 25, 2019 05:40 PM
scottscheffer
15
Aug 10, 2016 01:11 PM
DougMcCarty
1997 - 2003 F150
Mar 25, 2013 05:04 AM
Rhood
Electrical Systems/Wiring
Nov 1, 2005 09:41 PM
bill80132
Sep 8, 2003 09:41 AM
