Techron
Old Mar 6, 2020 | 01:01 PM
P G's Avatar
P G
Techron
Does anyone know if there are any benefits of using regular techron in diesel engines? Thnx
Old Mar 6, 2020 | 08:17 PM
carbon coupe's Avatar
carbon coupe
I use Lucas as well as the standard Ford fuel conditioner. I also use top brand fuel at all times.
I know this doesnt answer your question. Just do some research. I read somewhere about a mix of ATF and something else in diesel fuel but never followed up on it. Maybe try the engine forum.
Old Mar 8, 2020 | 10:39 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I'm using Opti-lube Summer+. They win every independent lab test time after time...and it actually does what it says it will according to those tests. Costs me about $2.08 per tank to treat 44 gallons.
https://opti-lube.com/opti-lube-dies...SABEgI_mvD_BwE
Old Mar 8, 2020 | 10:49 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Old Mar 9, 2020 | 11:30 AM
DavenTn's Avatar
DavenTn
Why do you believe you need a fuel system/engine cleaner? A few tanks of bio blended diesel will do a better job at clean up. The only way to know is have your oil analyzed.
Years ago I used it in a Ford Explorer (gasoline additive) and noticed an improvement.
Old Mar 9, 2020 | 11:55 AM
ford390gashog's Avatar
ford390gashog
I would suggest not using it in a diesel Chevron had a standpoint on it. They do make a green label bottle for diesel engines called Techron D.
APPLICATIONS
TECHRON Concentrate Plus is designed for gasoline
carbureted or fuel injected spark ignition engines. To
keep the entire fuel system clean, use TECHRON
Concentrate Plus every 3,000 miles or at scheduled oil
change intervals, not to exceed twice per oil change.
Will not harm catalytic converters and oxygen sensors.
Not recommended for air-cooled two-stroke engines.
Not recommended for diesel engines.
Old Mar 9, 2020 | 10:23 PM
Lance Helmert's Avatar
Lance Helmert
2 stroke oil does well in diesel fuel additive tests. I run it in my semi.
lud04X
General Diesel Discussion
Jul 8, 2014 12:35 AM
