DRW offset/inset backspacing
Old Mar 2, 2020 | 08:02 PM
NCMillwright's Avatar
NCMillwright
I’m looking to get a new set of wheels for my 18’ f350 drw. Truck has stock 5 hole aluminum wheels. I’ve been searching around about offset/inset and backspacing. I’m still a little confused about the dually numbers, so I’ll tell y’all what I want to achieve... I’m putting a 3.5” leveling kit on the truck. I want to run either 35x10.50, 35x11.50, or up to 37x11.50. If I can run any of the above sizes on stock wheels safely that would awesome.
I want ant to stay in the stock 17x6.5 wheel size range... or up to an 18x7.5/8”. I don’t want 20” or bigger.
can some people post their 17+ duallies with 35-37s and include wheels specs?
Old Mar 2, 2020 | 08:10 PM
Lamoon78's Avatar
Lamoon78
Up to 11” wide you will be fine on the stick 6.5” rims and also without the use of spacers.
Old Mar 2, 2020 | 08:14 PM
StonedGrey's Avatar
StonedGrey
how does 22” wide worth of rubber fit on 13” of wheels and not rub the rears together?
Old Mar 2, 2020 | 09:38 PM
Lamoon78's Avatar
Lamoon78
Thats how right there.
Old Mar 2, 2020 | 09:40 PM
Lamoon78's Avatar
Lamoon78
The manufacturer spec on that tire is 11” wide did I tape it no but 10.50 will fit with no problem. I have had around 11,000 pounds on these and they still dont touch.
Old Mar 2, 2020 | 09:42 PM
StonedGrey's Avatar
StonedGrey
Ok. No need to get snippy. It was just a question.
what size are the tires?
My 18 with stock tires hardly had any gap.
Old Mar 3, 2020 | 04:39 AM
Lamoon78's Avatar
Lamoon78
265/70/17 and actually the shop I use for tires that told me these would fit even though I questioned the width. He has quit a few Ford guys that are putting 285 on these trucks.
Old Mar 3, 2020 | 11:58 AM
StonedGrey's Avatar
StonedGrey
10.4” width according to the tires size calculator. Just for reference to help people.
So we know this size works.
Old Mar 3, 2020 | 03:20 PM
Lamoon78's Avatar
Lamoon78
Depends on manufacture most are in the 10.4-10.8” range but there is a few that shows 11.0 though. My tire guy told me that Fords are the only duallys you can run the 265 on without spacers and even 285 as well but you cant pull with the 285 cause that will make them touch.
Old Mar 4, 2020 | 06:11 PM
NCMillwright
So I’m good running 35-37 x11 and pulling? When I’m traveling I am pulling 8k TT, propane bottles and tool chests in bed, + some other miscellaneous items in bed. I’m at about 1500lbs in bed when traveling and then towing
Old Mar 4, 2020 | 06:25 PM
Lamoon78's Avatar
Lamoon78
According to the manufacturer of my tires they are 11” wide and I have plenty of space. So you should be.
Old Mar 4, 2020 | 06:39 PM
NCMillwright
Cool deal thanks
Old Mar 6, 2020 | 09:15 PM
NCMillwright
I do have another question. If I were to go to an aftermarket set of wheels would I need to get both F/R/ and inner wheels? Or would I just need the 2 front and 2 rear?
Old Mar 6, 2020 | 09:27 PM
Lamoon78's Avatar
Lamoon78
Im doing aftermarket right now unless you change sizes all you need is front and outer rear if you go with something other than the 17x6.5 then all 6
Old Mar 7, 2020 | 03:44 PM
NCMillwright
Alright I appreciate it
vavtx
Jan 4, 2022 11:08 PM
killaglide
Nov 30, 2019 01:31 PM
opielab
Aftermarket Products
Apr 15, 2015 09:21 PM
nut1605
May 3, 2013 06:22 PM
brainchild
Jan 8, 2005 09:50 PM
