Jack Clearance
Old Mar 2, 2020 | 05:07 PM
Colu41's Avatar
Colu41
Jack Clearance
So am looking into a new floor jack for the garage but. Am a little worried the average jack won't even come close to getting my F150 wheels off the ground.
Any suggestions? Stock suspension, and I measured 22" ish from the ground to the rear leaf springs. So most floor Jack's are only rated for I think 18"ish inches.
Old Mar 2, 2020 | 06:00 PM
CJM8515's Avatar
CJM8515
do you have a harbor freight nearby? They sell a really nice daytona brand yellow colored jack that will work. I think it goes to about 24", even so if you need a bit more a small piece of 4x4 will work fine say 3" high give or take. You shouldnt be lifting by the leaf spring, you should lift the frame as its much lower.
Old Mar 2, 2020 | 06:45 PM
Colu41's Avatar
Colu41
Wont be lifting from the leaf as that's just what I measured to quick. And yes as a matter of fact a Harbor Freight just opened up last week here. Lol. And I saw those Daytona's but never looked into them.
Old Mar 2, 2020 | 06:47 PM
ford390gashog's Avatar
ford390gashog
The trucks very easily lifted from the frame with a 19" capacity jack. However unless you feel the need just jack it from the rear axle and front A arms it's much faster.
Old Mar 2, 2020 | 07:05 PM
Colu41's Avatar
Colu41
Ok. Most of the floor jacks Ive seen so far have a 18 1/8"m lift height. Would I need something taller? The ones Ive found that go higher are only about 19 1/8" and they're twice the price.
Old Mar 2, 2020 | 09:35 PM
jr105's Avatar
jr105
I use a jack with about 19" lift and a piece of 4x4 between it and the frame and I can get both wheels on one side off the ground easily.
Old Mar 2, 2020 | 10:06 PM
KJ Smith's Avatar
KJ Smith
Where are you lifting it.?
I know there is a jack point with an arrow on the frame behind the front wheel.
Old Mar 3, 2020 | 07:07 AM
SpencerPJ's Avatar
SpencerPJ
I use to do that. Now I have 2 Harbor Freight jacks, soooo much nicer
Old Mar 3, 2020 | 08:32 AM
jr105's Avatar
jr105
I have a SuperCab and I lift it near the center the driver's door. Using a foot long 4x4 spreads out the contact point on the frame so it's not scratched or dented.
Old Mar 3, 2020 | 09:03 AM
Colu41's Avatar
Colu41
Which Jack do you have from HF?
Old Mar 3, 2020 | 02:25 PM
SpencerPJ's Avatar
SpencerPJ
I must be honest, I am talking about my YukonXL. I have a 2020 F150 on order, do any day. Trust me, I'll get a couple 4x4s if I have to. When I jack the Yukon, I slide one under a plate that holds axle to leaf springs, front under some strong stearing frame part. I do not per-se go after frame lift. I seem to have plenty. I do not know what it will be like with the F150. Harbor Freight has a great selection, but lifting from the frame you will have to extend the suspension, where as lifting where I do, you do not.
Edit: My jacks are so old they are not even listed on their website. I have 2, 2 ton jacks.
Old Mar 3, 2020 | 06:27 PM
GABAR's Avatar
GABAR
Northern Tool has one that lifts a bit over 23 inches for $208.00 .
You can always stack a block of wood or two on the jack pad to give you more clearance while jacking your vehicle up but regardless, once you get it up, use a jack stand or two.
Old Mar 3, 2020 | 07:22 PM
KJ Smith's Avatar
KJ Smith
I thought that also.
Turns out that's not the case.
Jacking up from the jack point on the frame is the easiest way.
Old Mar 4, 2020 | 07:10 AM
SpencerPJ's Avatar
SpencerPJ
Thanks, I look forward to investigating.
Also, do be careful with blocks, I personally prefer the jack and lip for security, but will / would use a block. Jack stands for sure, even if just placed under and close as a failsafe.
Old Mar 4, 2020 | 11:53 AM
TJReams's Avatar
TJReams
Are you getting antsy on your new truck yet? I know how impatient I got after the Serial number was issued for mine. I checked the builders link almost every day following the build.
TJ
