O2 downstream no cats no threadport
The code 1131 is a Lean code indicating either the intake tract is allowing excess air or the flange is allowing air ingestion ahead of the front Ox sensor it is detecting.
We need to know the extent of the modifications made.
For instance, are the cats removed?
Was Hedders installed?
The front sensors both sides control fuel injection cylinder by cylinder in real time as the motor runs. If they are missing or not operational, the computer substitutes a fixed fuel table value that will be constantly on the rich side, by intent.
The rear sensors being close to the last cats, monitors the oxygen output. The computer monitors their reading and compares to the front sensors as a way to tell the health of the whole cat system both sides by using a Ratio calculation. The rear sensors do not control any fuel injection, only monitors the cats.
If this system become non operational, expect to see codes 420/421 at some point. You can look up those codes that will support the failure by description.
Also, the Ox sensor codes will be confirmed by looking at the Long Term Fuel Tables with a Scanner to see their shift in values from a Zero point in percentage rich (+) for a lean code and Lean (-) for a rich code. This is because the computer program is built to allow the system to counter the 'fault' up to a limit. That limit when a code is set. The ability to shift over a short shift is the way the system lives with short term changes drive cycle to drive cycle.
I'm sorry, but things are not as simple as you might have thought.
From this you see it's not so simple to defeat the engineered operation and have everything normal.
For example, with long tube Hedders you cannot sample all cylinders for each bank close to the heads where the system needs the sensor signals to originate because there it a time element 'window' for that signal so control of the next cylinder can be accomplished.
Putting the sensor in a Hedder collector so far down stream lengthens the time outside the window in addition the sensors operate too 'cool'.
Those who install long tubes most often don't know these things and the mfger/vendors do not tell or know.
The results are what you get from modifying outside hardware the computer senses and very often does not expect.
The computer program does not change anything but shift some tables from their normal operating ranges.
This often alters drivability reactions, set codes, violates Emission laws etc where applicable, causing some lost investment in time and money if the vehicle does not pass inspection.
I'm not telling you you can't do what you want, only to take time to explain the facts of life about such changes.
You don't get this anywhere else or you would not need to ask such a good question here.
Good luck.
Straight pipe in place of the cats that bank will result in code 420 at some point. The code may cancel the CEL at some later point because the failure is not useful to the system and does not affect drivability but is still set in program.
There is no cancelling the rear sensor from a missing Cat assembly on that bank.
The program was written so you can't get by it by any simple means.
US EPA dictates this beside being illegal to run without Cats or even for a Yard to sell them 'used'.
Good luck.
