Truck stalling and brake problem
Old Feb 29, 2020 | 02:36 PM
DAKPickup's Avatar
DAKPickup
Have an 89 150. Stalls at low idle when turning wheel. Also no brakes. New calipers, new fluid, bled brakes. Booster not leaking, master cylinder not leaking. Pedal goes to floor unless you pump it. Also sometimes idle jumps high to low in park. Please help...need this truck going for a service truck.
Old Feb 29, 2020 | 03:09 PM
yardbird's Avatar
yardbird
Are you leaking power steering fluid along the hose? There is a switch, for lack of a better word, that screws into the hose that when the wheels are turned will send a signal to raise the idle. They will start leaking fluid and go bad.
Old Feb 29, 2020 | 04:53 PM
88n94's Avatar
88n94
Did your brake pedal act normal before the brake work? Are the bleeder valves on your new calipers toward the top? If the bleeder valves aren't toward the top you probably got them on the wrong sides, drivers side on passenger side and visa versa. Just a thought.
Old Feb 29, 2020 | 05:47 PM
torq'ta 5 8's Avatar
torq'ta 5 8
did you check your rear wheel cylinders, for leaks, did you start on passenger rear, then driver rear, then passenger front, then driver front, when you bled them
jamesmm
Jun 18, 2015 11:08 PM
DesertStorm
1983 - 2012 Ranger & B-Series
Jan 18, 2012 10:34 PM
FoPar1972
Jan 17, 2012 05:17 PM
Stoney57
Aerostar
33
Mar 18, 2006 06:51 AM
blatherskite
Nov 20, 2002 05:37 PM
