351M "straight up cam timing"
Old Oct 23, 2003 | 03:31 PM
Brian S's Avatar
Brian S
Start with Comp Cams tutorials
for some backround info about cam terminology.
http://www.compcams.com/information/tutorials/
Old Oct 23, 2003 | 04:52 PM
bubbaf250's Avatar
bubbaf250
would you recommend cutting another keyway into the crankshaft sprocked... ?
Not unless you are a skilled machinist with way too much time on your hands.
It would be easier to change the crank sprocket if you want to change the cam timing.
Most aftermarket crank sprockets are available only in a set, with a matched cam sprocket and chain.
Old Oct 23, 2003 | 08:56 PM
Redone's Avatar
Redone
So if I get a new cam (like we've been discussing in another post) then I would also need a new timing chain with sprockets, correct? I mean using the originals would defeat the purpose of buying a performance camshaft, right?
Old Oct 24, 2003 | 06:27 AM
danlee's Avatar
danlee
Yes, get a double roller timing set. You can get a Cloyes set for about $70.00, but PAW sells their own brand for $40.00.
Old Oct 24, 2003 | 01:04 PM
user 478546's Avatar
user 478546
You really don't want to ever change on timing gear without changing the other as well as the chain. I have a first-hand nightmare with only changing a gear and retaining the rest on a Dodge 400. For the cost and peace of mind, change out the whole timing set, then you should be good for thousands of miles.
Steve
Old Oct 24, 2003 | 01:23 PM
willd's Avatar
willd
Basic rule of thumb on any type of chain, be it bicycle, timing, motorcycle or otherwise. If you put on one new part the rest of the worn parts will either try to conform to the new one and self-destruct, or they will make the new one conform to them and cause it to self-destruct.
Old Oct 24, 2017 | 12:45 PM
Teardown4fun's Avatar
Teardown4fun
Trailering
I know it’s been 15 yrs haha but Imo, I think you put the after market keyway on the advanced slot to make it straight up. I’m fixing to do it so if any one is still subscribed to this thread correct me if I’m wrong. Thanks
Old Oct 24, 2017 | 06:25 PM
danlee's Avatar
danlee
If your timing gear has 3 slots, one is 4 degrees retarded, the next is 0 degrees(straight up), and the third is 4 degrees advanced. The factory timing set was 4 degrees retarded.
Old Oct 24, 2017 | 07:56 PM
Teardown4fun
Trailering
So the 4 degree advance slot will actually make it 8 degree advanced on a 3 slot crank gear. Will that work?
Old Oct 24, 2017 | 08:06 PM
danlee's Avatar
danlee
No, 4 degrees advanced is 4 degrees advanced. 0 degrees is Zero degrees. 4 degrees retarded is 4 degrees retarded. The factory TIMING SET was 4 degrees retarded. The cam is neither retarded or advanced, until the timing set is installed.
Old Oct 25, 2017 | 09:57 AM
Teardown4fun
Trailering
Ok got it, thanks, everything I’ve read confused me. Because such a small difference in the two sprockets.
Old Oct 25, 2017 | 11:37 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
PAW.Man,there's a trip down memory lane.
Nothing Special
36
Nov 23, 2021 11:34 AM
j66b
Feb 17, 2018 12:03 AM
hail destroyer
17
Dec 9, 2016 01:01 PM
Kyle Wood
Jun 22, 2016 10:44 PM
farmpaw
20
Mar 20, 2016 06:41 PM
