Small gas tank size
Small gas tank size
I have a 2017 F150 XLT 4 door 4WD. I have a pretty small gas tank at 23 gallons and I feel like I’m always filling up. Does anyone here know if there’s room underneath for me to have the current gas tank removed and have a shop install a larger one like 30+ gallons? Also how much ballpark would it cost me to have a shop do the entire installation for me? Is it a complicated process? Thanks
Welcome to FTE!
Yes, there's room, you can have the optional 36 gallon tank installed. I would ballpark it around $1000 if you have a shop do it. And it's been done, repeatedly:
https://www.ford-trucks.com/forums/1...swap-done.html
There are lots of threads on this, but that one has pics and maybe video of the whole job.
Good luck with it!
Good luck with it!
Just thinking out loud here. But wouldn't a nice Diamond Plate, bed mounted tank be larger, cheaper, and easier to install? Not only that, but it can be tee'd and gravity fed into the existing fuel line. So when both tanks are filled, your gauge would continue to show "FULL", until the fuel in the bed mounted tank was exhausted, and the level of the main tank began to drop. I had a similar arrangement installed in a Volkswagen Rabbit Diesel, and it worked very well. With both tanks filled I had a 1,000 mile range.
These newer trucks have way to many computers.
Last I searched, no one is offering an auxilary in-bed gasoline tank. Maybe a transfer tank.
You can get away with a lot of things with diesel. Gasoline not so much.
The OP says he has a 23 gallon tank, that means he has a 3.0 diesel and there is no other tank that can be swapped. If the OP has a gas truck it has a 26 gallon tank and can be swapped to a 36 gallon tank. He also would not be able to use a in bed transfer tank for gasoline.
He must be confused by thinking he has a 23 gallon tank when he actually has a 26 gallon tank.
Titan has a new t48 gallon tank for the F150 3.0 diesel! https://www.stage3motorsports.com/70...-Bed-Only.html
