How do you remove wheel well liners?
Old Feb 21, 2020 | 03:45 PM
swankerme's Avatar
swankerme
Title says it all. I have front wheel well liners installed in my 17 F-250. For the life of me I cannot remove them! I unscrewed three bolts and remove three pop rivets on each. They seem to be stuck on something and I don't want to break them trying to force them out. Any tips?
Old Feb 21, 2020 | 04:35 PM
sbrennan007's Avatar
sbrennan007
Are they the optional plastic ones or the standard felt covered ones? I know when I put the rear wheel well liners in it was a combination of a 'friction fit' and then a couple screws and a pop in plastic peg to mostly keep them from moving around.
I know on the felt ones, there are a few things that are secured on the liner with those pop in plastic plugs that hold wiring and the such...
Old Feb 21, 2020 | 04:36 PM
sbrennan007
Should have mentioned, I have an XLT, and I know the Lariat and up trim levels have some other plastic parts to keep dirt, mud etc... out of the front bumper.
Old Feb 21, 2020 | 05:17 PM
swankerme's Avatar
swankerme
These are the aftermarket plastic ones. I put them in a couple years ago, but it was apparently easier than taking them out!
Old Feb 21, 2020 | 08:12 PM
ForCal's Avatar
ForCal
I didn't think aftermarket front liners were even available. Do you remember the brand?
Old Feb 21, 2020 | 08:30 PM
wb6anp's Avatar
wb6anp
Mine are Fords, but Husky has them also.
Old Feb 21, 2020 | 08:37 PM
ForCal's Avatar
ForCal
I knew there were several choices for the rear liners, but thought OEM was the only optuon up front. Ill have to a look at Husky front liners.
Edit- searched the Husky site, they only have rears.
Old Feb 21, 2020 | 10:40 PM
StonedGrey's Avatar
StonedGrey
I have the OEM liners on the front of mine. There is for sure more then 3 bolts that hold them in. Theres small hex head bolt/screws that are 6 or 7mm along the edges of the wheel openings. Cant remember the size exactly off the top of my head. Then theres bigger bolts in the middle of the liners. And pretty sure some clips on the inner bottom edges. Kind of have to finagle them out once all the screws and bolts are out.
Daviddc114
Feb 4, 2011 12:20 PM
k3v1n
Nov 15, 2010 01:22 PM
jesterdog
Nov 12, 2009 02:07 PM
apropos
Apr 13, 2006 01:03 PM
DOGINIT
All Things Towing
Nov 13, 2004 01:47 PM
