2WD "Stance" and axle width
Old Feb 21, 2020 | 03:05 PM
niko20's Avatar
niko20
I've noticed that on the 2WD 78-79 Fords the rear axle is narrower than the front, which to me, I don't like. Makes the truck look wimpy. On my '79 F350 for example, the rear tires are set in about 1 inch inside the fender lip, whereas my front tires are pretty much even with the fenders. I hate it!! That's why I was looking into putting some spacers on the back. But then I would probably have bearing or lug issues. GRRRR
But yet on the 4WD Fords the axles look the same width, so you get a nice mean appearance where all four tires properly line up with the fender lips.
I think I may have read somewhere that even on some more modern trucks, its common that the front and rear don't track exactly the same width.
What was the reason they were made like this? Was it to allow heavier loads on the rear or something?
Old Feb 21, 2020 | 03:45 PM
fordguy2100's Avatar
fordguy2100
Depending on what rims you are running, you could look for the same style with a different backspacing that would even them out.
Old Feb 21, 2020 | 06:50 PM
somethingclever's Avatar
somethingclever
I believe axle widths are the same 2wd or 4wd.
Just run 1” wheel spacers or get wheels with different offsets.
Old Feb 25, 2020 | 09:06 PM
RalphXL's Avatar
RalphXL
I never noticed any axle width differences on my '79.
Jess
Old Feb 26, 2020 | 02:27 PM
niko20's Avatar
niko20
i was looking at a set of spacers but i also saw horror stories where the lugs pulled out of the spacer...so that scared me off some
also, i am a little concerned about extra wear on the bearings. Granted, rear bearing are probably tough as hell on a one ton F350 anyway
Old Feb 26, 2020 | 05:45 PM
caravaggio2000's Avatar
caravaggio2000
Just get rear wheels in the same style but with different backspacing and be done with it.
Old Feb 26, 2020 | 07:09 PM
niko20's Avatar
niko20
what about when i get tire rotations then lol
Old Feb 27, 2020 | 09:14 AM
5851a's Avatar
5851a
Never bothered me, especially from behind the steering wheel. I get more irritated with body panel gaps.
Old Feb 27, 2020 | 11:50 AM
fordguy2100
rotate side to side or if you really want to spend the money, remove and remount
Old Feb 27, 2020 | 02:57 PM
somethingclever
Did you know that trucks like yours often (if not always) came with wheels that were 9.75" wide and carried a heavier wt rating?
That wheel obviously widened the track width by a couple inches each side.
Again, in original form, i believe your D70 axle has the same WMS to WMS as the D60 3/4 ton trucks.
The load on the bearings would be the same with a 1" spacer as it would a wider wheel.
bigrigdually
6.4L Power Stroke Diesel
16
Oct 1, 2010 07:04 AM
ken selvy
Jun 22, 2009 11:59 AM
FordF350Baby
Jul 22, 2008 07:46 PM
scroller bill
1978 - 1996 Big Bronco
Oct 31, 2006 09:44 PM
bigblocksix
Offroad & 4x4
Dec 8, 2004 10:46 AM
