7.3 ltr running issues
Old Feb 21, 2020 | 11:41 AM
akpolaris's Avatar
akpolaris
Have a 97 & 7.3, F-350 with some issues. The muffler was cut off by a previous owner.
1) When it is sitting outside idling I find a red substance in the snow dripping off the left rear tire. The only thing I can figure is that it is unburned fuel coming out of the exhaust. Not brake fluid and only occurs when the engine is running
2) A check engine light that comes on intermittently. On when initially started then goes off after a short while. The truck was recently on a scope and I was told the codes are all cleared. I have an OBDII code reader and it retrieves no code
3) Recently it has stalled out, quit running, twice, at a stop sign. At idle. Also while coasting the engine has bucked or faultered. When I accelerated or applied power during this faulter it recovered.
Thanks for any ideas
Old Feb 21, 2020 | 01:17 PM
knottyrope's Avatar
knottyrope
red could be ATF
drain some fuel from bowl and see if its red
is your antifreeze red or pink?
Old Feb 23, 2020 | 11:03 PM
akpolaris's Avatar
akpolaris
I just replaced the fuel filer and my fuel is clear. I'm not burning died fuel, fuel from the house tank. The transmission is clear and dry. I just changed the oil and no sign of H2O in there. Completely stumped me on what it is. At least this occurs when it is engine running. The faltering and stalling out are a separate and possibly more concerning issue
Old Mar 3, 2020 | 12:52 PM
akpolaris2's Avatar
akpolaris2
So I have replaced the cam position sensor and then the ICP which seemed to resolve the quitting while running problem. The cam position sensor was indicated to need replacing by a scan but the culprit involved in quitting while driving sown the road appears to be the ICP
Old Mar 4, 2020 | 05:42 AM
97-psd's Avatar
97-psd
Glad you got the running issue resolved. Did you sort out the red fluid?
Old Mar 4, 2020 | 10:57 AM
akpolaris2's Avatar
akpolaris2
No I haven't. It isn't flammable, doesn't smell or feel like anti freeze or anything i recognize. Just wait, watch and see what turns up next
Old Mar 5, 2020 | 01:02 PM
knottyrope's Avatar
knottyrope
maybe kids put a toy up the pipe?
Old Mar 11, 2020 | 12:33 PM
akpolaris2's Avatar
akpolaris2
Bahstun, huh? I grew up on the south shore.. No longer any kids at home thankfully
Old Mar 20, 2020 | 01:30 PM
knottyrope's Avatar
knottyrope
close to it, more like foxboro area
Old Mar 21, 2020 | 12:07 PM
akpolaris2's Avatar
akpolaris2
I grew up in Marshfield. Been in Alaska since 79.
rebauto
Jun 28, 2019 02:09 PM
Brandon Keese
Feb 16, 2019 02:27 PM
Jim Rowley
24
Sep 18, 2008 10:49 PM
EX GM GUY
Jul 18, 2003 09:25 PM
