4.9 Timing Covers Interchange-able?
Old Feb 20, 2020 | 07:45 AM
N A's Avatar
N A
I need to replace the timing cover on my 1994 4.9, the rubber failed on the harmonic balancer and it worked its way back cutting a groove in the cover and a pretty good oil leak. I'm replacing the balancer and need a new cover. Are they interchangeable between earlier, 80's models and the 90's models?
I would assume that any Ford 4.9 from the 80's and 90's would have the same timing covers and bolt patterns?
Thanks!
Old Feb 20, 2020 | 08:37 AM
My4Fordtrucks's Avatar
My4Fordtrucks
$54 from Rock Auto brand new. Looking at a few different years , they appear to be the same as long as it had a serpentine belt. Do you already have one that you want to use?
Old Feb 20, 2020 | 10:15 AM
N A's Avatar
N A
https://www.rockauto.com/en/catalog/...ing+cover,5737
Are you looking at the first one - for $54? The one I pulled of the truck looks like the other one for $128 - which is what I've been searching for and finding new for >$125 and used for around 30-50 bucks (but from different years, and just wanted to make sure they would work, they look identicial to my untrained eye)
I actually just found this one on ebay https://www.ebay.com/itm/FORD-240-30...QAAOSwaEhZLwmn
which I might pull the trigger on, but I was hoping for confirmation this would work on a 1994 since I can't inspect and compare side by side with the one I took off.
chrisjr2287
Feb 12, 2023 09:57 AM
FLATFORD1976
Aug 27, 2009 12:10 AM
DIRTY_D
Apr 12, 2007 10:27 PM
apachetech
Mar 22, 2006 06:27 PM
ole_blue
Jan 26, 2002 09:53 PM
