Fan Runs When Door Opened
Old Feb 17, 2020 | 08:38 AM
Beefford's Avatar
Beefford
2018 2.7 SCrew
I have noticed recently that when i open the driver door of the truck when it is not running the fan will kick on for 30 seconds or so. Never noticed it when new, have about 56k on it now. Is this normal? Anyone else notice?
Old Feb 17, 2020 | 10:22 AM
GABAR's Avatar
GABAR
Originally Posted by Beefford
2018 2.7 SCrew
Never heard of that happening before but I’m very interested in hearing from other owners of the 2.7.
Old Feb 17, 2020 | 08:34 PM
agpopp's Avatar
agpopp
2.7 here, mine does it, and I think it's the fuel pump priming not the fan. But if you're actually hearing the fan, are you talking radiator fan or hvac?
Old Feb 18, 2020 | 06:54 AM
Beefford's Avatar
Beefford
Fuel pump would make more sense but it sure sounds like a fan. I've never actually popped the hood and looked, it's just been a little annoying observation in my mind. I'll pop the hood and dig a little deeper. Thanks.
Old Feb 18, 2020 | 07:12 AM
YoGeorge's Avatar
YoGeorge
The fuel pump primes when you open the door, so it does not take additional time while starting it. New on 2018 F150's. It is a feature, not a problem.
Old Feb 18, 2020 | 04:32 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'll be interested to know what you find.
Old Feb 18, 2020 | 05:41 PM
YoGeorge's Avatar
YoGeorge
Quote from a post in the thread below from forum member ford390gashog:
"Just so it's clear, the 5.0 also has the same direct injection and port injection for 2018. All engines do except the 3.3. The prime on door open allows the fuel system to bleed down which prevents the early failure of the HPFP shaft seal. Conversely the pump needs fuel immediately or else it will destroy itself from a dry start. Being tied to the door it gives the truck time to actuate the pump before the key is turned. The delay was not built in to the key because of a possible nuisance delay situation. Also if you remote start a 2018 there is a delay for the fuel pump built into the strategy. This is how it was explained to me by a Bosch systems engineer during a trade event. Other manufacturers are doing it also."
https://www.ford-trucks.com/forums/1...ng-door-3.html
Old Feb 19, 2020 | 07:42 PM
Beefford's Avatar
Beefford
Did some investigating, it’s definitely the radiator fan. Only occurs when the motor is cold and is only the driver door. Fan runs for almost 3 minutes and shuts off. Really weird. I tuned the truck a couple months ago. Wondering if it started then.
Old Feb 19, 2020 | 08:47 PM
agpopp's Avatar
agpopp
That's definitely a problem. Sounds like the tuner guys programmed the wrong pin for the fan instead of the fuel pump. Hopefully the pump is also priming so it's not being fired dry. I'd give give them a call for sure.
Old Feb 19, 2020 | 09:32 PM
GABAR's Avatar
GABAR
Have you tried removing the tune and going back to stock to see if that solves the issue?
Old Feb 21, 2020 | 10:24 AM
Beefford's Avatar
Beefford
Tune removed, fan stopped running, fuel pump primes as it should. Great.
Old Feb 21, 2020 | 12:05 PM
CR172's Avatar
CR172
What tune ?
Old Feb 21, 2020 | 02:13 PM
Beefford's Avatar
Beefford
SCT BDX tuner, 93 octane pre load. I called them, they've of course never had this issue. Told me to monitor the air-fuel ratio on the handheld when starting to see it its in parameters. Will do tonight.
Old Feb 21, 2020 | 02:27 PM
YoGeorge's Avatar
YoGeorge
Good news. Makes me that much more concerned that someone's flaky tune will do something to really kill your vehicle.
Old Feb 21, 2020 | 02:42 PM
CR172's Avatar
CR172
I've been running a tune for almost 30K miles with absolutely no issues. Granted a different tune than the OP.
