ABS not working on 1992 f-250 4x4 w/460
Old 10-13-2003, 10:57 PM
MCalvin460CI's Avatar
MCalvin460CI
MCalvin460CI is offline
I have a 1992 f-250 4x4 with a 460 and an E40D tranny. My brakes seem to be locking up and i have a pull and vibration when i brake hard. The pads look fine, but i just bought the truck and am the 3rd owner so im not sure when they were replaced. How can i tell? Should the brakes lock up? what can i do?
Old 10-13-2003, 11:03 PM
Just4Ford's Avatar
Just4Ford
Just4Ford is offline
Your truck has a RABS which is supposed to modulate pressure to the rear to prevent lockup. If you are getting a pull and vibration while braking you need to check for warped rotors. BTW your front brakes will lockup during panic braking. Justin
Old 10-13-2003, 11:13 PM
MCalvin460CI
why do u think my rears would be locking then? they shouldnt be right. how can i fix it? let me know. thanks
Old 10-16-2003, 05:34 PM
Just4Ford's Avatar
Just4Ford
How tight is your emergency brake pedal? It could be overtightened. Have you seen your RABS light on at all? I would remove back drums and inspect shoes and lube up the points where the shoes touch the backing plates. Justin
gabyski
1999 to 2016 Super Duty
30
01-08-2017 07:31 PM
MCalvin460CI
10-15-2003 02:02 PM
Mr Personality
12-04-2002 11:52 PM
Quick Reply: ABS not working on 1992 f-250 4x4 w/460
