Cluster reset button missing/radio won't turn off with truck
I just bought a 2006 F-250 XL and fixing a few things and went to go cycle through the cluster and can't seem to find the reset button. There is no button where it's usually at on most vehicles and can't find it anywhere and there are no forums for this so I feel stupid posting but I'm desperate. Also the radio won't turn off after I shut the truck off and still shut off after I open the driver side or the passenger door. Please help.
Of course...............for 2006:
The instrument cluster carries out a display prove-out to verify that the warning/indicator lamps and monitored systems are operating correctly. The safety belt warning indicator proves-out for 65-seconds or until the safety belt is fastened. The malfunction indicator lamp (MIL), and the wait to start indicator (diesel engines) illuminate continuously until the engine is started and operating normally. When the ignition switch is turned to the ON position with the engine off, the following indicators illuminate for 3 seconds :
My initial observation: you have a gremlin in one of the modules (lesser likelihood) such as body control or in the hybrid electronic instrument cluster (higher likelihood). That hybrid instrument cluster has a microprocessor, CAN bus, UBP bus and data flows between the cluster, trailer brake control unit, electronic control unit, PCM, ABS module, vehicle security module, and the electronic automatic temperature control. That cluster circuit board (what a gargantuan Piece of Chit (POS) from Visteon --- disgraceful on Ford's part too for using this cheap, poorly manufactured, poor quality control CHIT) is prone to cold solder joints, microprocessor leads coming detached, pad problems, etc...............if you're good with Ohms Law, have a decent DMM you can troubleshoot pathways on the cluster board as it's largely discreet, you can also "reflow" the leads on the main microprocessor using relatively cheap gear from most electronics shops and fix other component problems, pathways with a decent soldering iron.....watch the heat !
- LOW RANGE indicator
- 4x4 indicator
- BRAKE warning indicator
- ABS warning indicator
- charging system warning indicator
- door ajar indicator
- air bag warning indicator (6 seconds )
- electronic throttle control
mrad
04-23-2016 08:00 AM
cwc-rummy
08-29-2014 04:49 PM
keld
1997-2006 Expedition & Navigator
01-18-2005 02:12 PM
