someine help me understand this please.
Old Feb 14, 2020 | 11:52 AM
gpeade's Avatar
gpeade
I have always pulled a conventional bumper pull style RV. I am considering a 5th wheel. My TV is a 2003 F-250 Crew cab short box with the 6.0 diesel. I was looking in the manual this morning at towing capacities. According to this my max trailer weight without a 5th wheel is 12,500 and with a 5th wheel it drops to 10,600. Why is that?
Old Feb 14, 2020 | 12:21 PM
mwheue's Avatar
mwheue
Fifth wheels generally put around 15-20 percent of their weight over the bed of the truck. What does your yellow sticker on your drivers door jam say as far as combined weight? Mine for example says 3480 and max fifth wheel towing rating of 12500 for my truck. If your door sticker says for example 2200-2700lbs you would max out on weight over the rear axle before hitting your max trailer weight.
Old Feb 14, 2020 | 12:31 PM
scraprat's Avatar
scraprat
Top Answer: 5
This is from the 2003 brochure I see 12,700#.
Old Feb 14, 2020 | 03:24 PM
gpeade's Avatar
gpeade
mwheue, that particular sticker isn't on a vehicle this old. Mine only lists GVWR which is 8800lbs
scraprat, the numbers I got were from the 6.0 supplemental manual that goes with the owners manual. I can't explain why each lists different numbers.
Old Feb 14, 2020 | 04:39 PM
jsm180's Avatar
jsm180
Here is the whole brochure.
https://www.fleet.ford.com/resources...s/2003_All.pdf
Michael Walton
All Things Towing
19
Feb 11, 2020 01:49 PM
Nicho1197
All Things Towing
21
Feb 22, 2018 08:28 PM
sgeorge
All Things Towing
17
Oct 3, 2017 12:38 PM
zephyr74
Mar 22, 2010 09:09 PM
Cowboy_351
All Things Towing
Apr 17, 2002 07:01 PM
