Problem with 1996 f250
Old 02-13-2020, 08:04 PM
Tim Dewey's Avatar
Tim Dewey
Tim Dewey is offline
Hello. I have a 96 F250 crew cab with the 7.5 L motor. Runs great lots of power But randomly it. Dies completely shuts off and will take about 15-20 minutes to restart. It will turn over but won't fire. I have sprayed carburetor spray in and it will not fire. So I'm assuming it's electrical. Does anybody have any suggestions?
Old 02-13-2020, 08:52 PM
torq'ta 5 8's Avatar
torq'ta 5 8
torq'ta 5 8 is offline
check for codes after it is at operating temp, when it dies, and you try to re-start do you hear the fuel pump run for 2-3 seconds, old days was sign coil going bad, gets hot, cools off fires up
Part 1 -How to Troubleshoot a No Start (Ford 4.9L, 5.0L, 5.8L).
yours should be 3 digit codes
(16) How to read a check engine light code on a Ford 1983-1995 EEC 4 system - YouTube
Old 02-13-2020, 08:59 PM
Tim Dewey's Avatar
Tim Dewey
1996 f250 problem
I have already changed the coil and do not have an engine light on.
Old 02-13-2020, 09:37 PM
88n94's Avatar
88n94
88n94 is offline
My guess would be the PIP in the distributor is bad. You have to remove the distributor and disassemble it to replace the PIP. It's easiest to get a different distributor, but to find a decent one. Most rebuilt distributors are junk. The best bet would probably be try a new aftermarket distributor.
Old 02-14-2020, 07:09 AM
torq'ta 5 8
doesnt mean you dont have stored memory codes, here are 2 test procedures, one checks ICM/TFI module, one checks PIP sensor
ICM/TFI module test
Part 1 -How to Test the Ford Ignition Control Module (Fender Mounted)
PIP sensor test(scroll down to TEST #7
Part 5 -How to Test the Ford Ignition Control Module (Fender Mounted)
Old 02-14-2020, 09:57 AM
88n94's Avatar
88n94
88n94 is offline
As far as testing the ignition components, if the part is not in a dead state it will likely test good. In other words you would have to do the test while the engine is in a won't start condition. Those tests are easier to do if the ignition component is totally dead, not intermittent.
Curated Content Editor
General Automotive Discussion
09-20-2019 07:53 PM
1999 to 2016 Super Duty
10-02-2017 04:33 PM
gatormccluskey
01-14-2012 12:26 PM
Quick Reply: Problem with 1996 f250
