Fuel system priming
Old Feb 12, 2020 | 03:14 PM
scottz99's Avatar
scottz99
Veteran: Navy
Fuel system priming
After draining the water separator or changing fuel filters, the manual calls for priming the system by turning the "key" on for 30 seconds, repeating two or six times. How do you do this with the button start (no key)? Does turning it on in accessory mode (don't press the brake) activate the fuel pump? Seems like it would not.
Old Feb 12, 2020 | 03:35 PM
lariatbob's Avatar
lariatbob
Just press the button without your foot on the brake....I think. Won't start but not sure if it will cycle the pump. You should be able to hear it.
Old Feb 12, 2020 | 03:38 PM
mtnguy's Avatar
mtnguy
What he said. ^^^
You can hear the fuel tank pump run when you do that.
Old Feb 12, 2020 | 05:12 PM
SUPERTRUCKERS's Avatar
SUPERTRUCKERS
EpicCowlick has a video for that! ...go to 3:43 in the video below...
Old Feb 12, 2020 | 10:04 PM
TeddyD's Avatar
TeddyD
When changing filters, I change the frame mounted filter then prime the truck. After it’s primed, I then change the engine mounted filter.
The above is correct for priming with a push start. Hit it once without foot on brake, wait 10 seconds, hit it again to turn off. Repeat about 6 times.
Old Feb 13, 2020 | 01:39 AM
scottz99's Avatar
scottz99
Veteran: Navy
Thanks for the info!
Old Feb 13, 2020 | 06:08 AM
Whiplash2130's Avatar
Whiplash2130
Filter change
https://youtu.be/i-13Q5N8e8M
Are you actually replacing the water separator during the filter change or just cleaning it?
Old Feb 13, 2020 | 12:11 PM
scottz99's Avatar
scottz99
Veteran: Navy
The water separator is not replaced unless something is wrong with it. The water separator and filter housing are the same unit. Remove the old filter, wipe the housing down, install new filter, done. Watch the video in post 4.
Old Feb 14, 2020 | 12:10 PM
2019er's Avatar
2019er
yup, and you'll hear it while it cycles too.
Old Feb 14, 2020 | 03:49 PM
speakerfritz's Avatar
speakerfritz
and the drivers door closed
if you push the button with the door open (standing outside of the truck), it will dry start even though you did not tap the brakes.
Old Feb 14, 2020 | 07:34 PM
TeddyD's Avatar
TeddyD
Mine doesn’t do that. That’s weird.
Old Feb 14, 2020 | 08:17 PM
scottz99's Avatar
scottz99
Veteran: Navy
I don't think mine reacts like that either; have to check.
Old Feb 14, 2020 | 08:24 PM
ForCal's Avatar
ForCal
It doesn't, it will only start if you press and hold the button for 3 sec. No need to press and hold the button to prime.
Old Feb 14, 2020 | 10:01 PM
scottz99's Avatar
scottz99
Veteran: Navy
Did not know that, thanks.
Old Feb 14, 2020 | 10:10 PM
ForCal's Avatar
ForCal
What part?
