I can't find that tag in my books but I can tell you 3.07 is gear ratio,and is probably a Dana d7ta- is 1977. Take a picture of the warranty tag on the drivers side door and I can tell you what it came with.
3.07 is the gear ratio
d7ta-b3f is the ford designation for axle parts (d7t= 1977 truck)
751400-1 is the Dana BOM (bill of materials) so you can search Danas website to see what all that axle was put under. (This BOM denotes Ford F100 Dana 44)
MEX - not sure cz this spot is different depending on axle tags but this could be the assembly plant code which would be Mexic built.
