Shocking Excursion photo !
Old Feb 1, 2020 | 08:41 PM
pirate4x4_camo's Avatar
pirate4x4_camo
ok the headline is click bait but still a fun pic.
My Excursion with 900 gallons of Jet A ( 7.3 loves the stuff ) and the Fox shocks Helo and Raptor. ( yes he developed the shocks for ford )
The owner has forgotten more about shocks then I will ever know, he is THE shock guru ! holds more shock patents then any other person or company.
i have been out building Hammer Town for King of The Hammers off road race for the past 3 weeks and he will be one of 4 helos we use this week for filming the race.
Old Feb 1, 2020 | 09:47 PM
agsmv1's Avatar
agsmv1
That is freakin sweet!
Old Feb 1, 2020 | 11:03 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Very nice, Camo. Wish I could make it out to see the race this year...maybe after I retire next year.
Old Feb 1, 2020 | 11:57 PM
pirate4x4_camo
if you ever do plan a trip to KOH be sure to PM in advance, I will hook you up.
Old Feb 2, 2020 | 07:27 AM
mta5002414's Avatar
mta5002414
What lube additive do you use when running the "A"?
Old Feb 2, 2020 | 08:39 AM
pirate4x4_camo
none,
according to my fuel nerd it is not needed for the pump or injectors on a 7.3
Old Feb 2, 2020 | 09:15 AM
mta5002414's Avatar
mta5002414
Ok, I was just curious because of the differences between the two fuels. A friend of mine was a vaporhead at SJAFB and used to do the same but he stopped. Jet A is more “dry” but Diesel is made(or additives are mixed in) to lubricate the injector system. The viscosity is also different, Jet A is lower viscosity than Diesel #2. Lower lubricity is likely as the viscosity decreases. This may not cause catastrophic instant damage, but it may cause long-term wear of pumps, injectors. Diesel 2 is made with a required cetane number(ASTM D975 - minimum of 40). The ASTM specs for Jet A(ASTM D1655) has no minimum cetane rating. Because cetane pertains to compression ignition engines and has no meaning in turbine engines.
Old Feb 2, 2020 | 09:41 AM
rsqfxr's Avatar
rsqfxr
aw man i may have to show up, a bunch of coworkers are coming out thursday
Old Feb 2, 2020 | 09:50 AM
SmackDaddy's Avatar
SmackDaddy
Looks like a dusty takeoff
Old Feb 2, 2020 | 02:08 PM
M3rc's Avatar
M3rc
Sweet! Ever do the Baja 1000?
Old Feb 2, 2020 | 04:53 PM
pirate4x4_camo
have raced it many times , won 3 times driving and once as crew.
Old Feb 2, 2020 | 04:56 PM
pirate4x4_camo
not to bad, we have a water truck to keep it soaked down. if anything we spray muddy water around, at least at heli base shown, obviously out in the desert it is dusty.
Old Feb 3, 2020 | 05:23 PM
Big Sky's Avatar
Big Sky
Nice chopper!
Old Feb 5, 2020 | 09:53 PM
smokekiki's Avatar
smokekiki
I work on RR250 Engines, so have access to Jet A, and run it now and then. Jet A is high in sulfur , that is what acts as a lube,
Old Feb 6, 2020 | 09:46 AM
smokekiki's Avatar
smokekiki
In case anyone was interested, we just filled our tank for the test cell. Jet A in the southeastern Pa area is $2.67 a gallon today.
