Help! Help! Help!
Old Oct 13, 2003 | 03:44 PM
vf78ot's Avatar
vf78ot
Exclamation Help! Help! Help!
Ok, as I stated in my last post, I have a 1991 F150 5.0 4x4. I have put on a new throttle position sensor, spark plugs, fuel filter, and vaccum line to the throttlebody, because the old one broke. I am still having problems. Going up through 1st, and 2nd gear the truck is fine, but when the transmission goes into 3rd gear, when I hit the gas the truck begins to shake like it is missing, the engine does not race like it is slipping out of gear but the truck still shakes and vibrates, if I press the gas down harder it will shake and smooth out an accelerate, but when I let off and slow down and let the transmission go back up through the gears it will do it again in 3rd gear. It just repeats the process. HELP!
Old Oct 13, 2003 | 03:58 PM
dhermesc's Avatar
dhermesc
Are you sure your plug WIRES are good? I had a similar problem on a '9 with a 300 6.
Old Oct 21, 2003 | 11:31 PM
DPRICE1's Avatar
DPRICE1
my neighbor had the same problem with his 95 f-150 after I did a tune-up (plugs, distrib. cap, rotor and plug wires) it "runs like new again"
Old Oct 22, 2003 | 12:11 AM
Fully_Loaded's Avatar
Fully_Loaded
My torque converter went bad and it did similar things. I would check to see if the computer is throwing a torque converter slipping code. Assuming you have an auto.
