2020 250 gearing 3:31 or 3:55?
Always go with the lowest gear available. You will never wonder "what if?", you will always have the best mechanical advantage when needed (more 'seat-of-the-pants' power), and you will honestly never notice the 0.05 extra MPG of the lower gears on the highway. The 10 speed has a higher final OD than the 6 speed it replaced, so you can think of it as the 3.55's with the 10spd will pretty much be equal to the outgoing 6spd with 3.31's.
Joe T,
Can you please explain the rational behind holding 10th? Say 10th gear is held at 55mph or higher, with larger tires, 10th gear would need to be above say 60mph. Is there a lock out in the transmission and shifting back and forth would cause excessive wear. Serious question.
Went on the Gear Ratio Calculator website to see what the larger tires do to RPMs and speed. It's interesting the difference between 275/65/20 and 295/65/20 with 3.31 gears is around 2 MPH. If interested, I attached a doc with some of the differences.
Yup, here are the numbers
10R140
First 4.615:1
Second 2.919:1
Third 2.132:1
Fourth 1.773:1
Fifth 1.519:1
Sixth 1.277:1
Seventh 1:01
Eigth 0.851:1
Ninth 0.687:1
Tenth 0.632:1
Reverse -4.695:1
6R140
First 4.17:1
Second 2.34:1
Third 1.52:1
Fourth 1.14:1
Fifth 0.87:1
Sixth 0.69:1
Reverse 3.40:1
10R140
First 4.615:1
Second 2.919:1
Third 2.132:1
Fourth 1.773:1
Fifth 1.519:1
Sixth 1.277:1
Seventh 1:01
Eigth 0.851:1
Ninth 0.687:1
Tenth 0.632:1
Reverse -4.695:1
6R140
First 4.17:1
Second 2.34:1
Third 1.52:1
Fourth 1.14:1
Fifth 0.87:1
Sixth 0.69:1
Reverse 3.40:1
It's not necessarily acceleration, but the ability and ease of holding a gear without downshifting constantly with every hill or throttle input change.
I think the 6R140 held gear until like 900RPM if I remember correctly. Wonder what the 10R140 does. That is why I was playing around with the numbers. I figured with 1K+ torque, as long as you keep it above 1000RPM, it should hold the gear. Well, depending on the hill and how much throttle. I practice energy management by accelerating downhill and easing up hill. By the time I reach the top of the hill, I should be going the speed limit. Just the stupid games I play while driving! Again, depending on the size of the hill.
Lower gears used to be the common thinking, and you’ll still hear it here from guys used to driving underpowered trucks that need help to maintain speed under load.
Today, improved diesel power and technology has changed the approach, and higher gearing is producing more efficient torque management and pulling power.
In class 8 trucks just a few years ago, 3:73 were considered high, with 390 and 4:10 gears being the most popular.
Look at the ratios on these new class 8 over the road trucks.
https://www.truckpaper.com/listings/...state=oklahoma
#29
Compared to our trucks, our weight to power ratio in the new diesel is pretty impressive. 3:31 is still mid level. I can see 3:20 gears in the future.
#30
1,850 to 2,050. The 3:26 ratio is the most popular today. 3:08 ratios are out there also. Unless you are a heavy hauler pulling 150k, ratios are going higher...
