1991 E350 IDI QUESTION
Old Jan 30, 2020 | 07:09 AM
Olds64's Avatar
Olds64
If your FSV is bad here's one that you can use to replace the faulty unit:
I used this FSV in my 86 f250 and it works great. The OE FSVs are like hen's teeth. I'm not sure if LMC or Dennis Carpenter even carry them.
Old Jan 30, 2020 | 10:52 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
that Amazon link is kinda Messed up Calling it a 3 Port Valve ... you need to make sure it is a 6 Port valve ...
I just use the Cheap OEM style from FleaBay as you don't have to change the connector and the OEM quick connect lines fit so you don't have to cut your old OEM lines and add hose with clamps.
Pollak Valves are good I use em on Marine applications where we don't have Ford Fuel Lines and Ford wiring connectors.
Old Jan 30, 2020 | 11:57 AM
Olds64's Avatar
Olds64
Old Jan 31, 2020 | 08:38 AM
Sonny Bradley's Avatar
Sonny Bradley
Valve fitment
Originally Posted by Olds64
DOH!
Here's a better link.
https://www.amazon.com/ACDelco-U7001...KQE56YTW4EV29Y
Like Lonewolf said, you do have to splice a new connector into your harness if you use this FSV.
Thank you guys again for the info and links. Very helpful. I clicked on the last link from olds64 then looked under ford to find only f250 and f350. My ambulance is an E350 which I imagine it would use the same valve. The only issue is it says that part only fits 2000-newer vehicles. Mines a 1991.
Old Jan 31, 2020 | 09:26 AM
Olds64's Avatar
Olds64
Sonny, the FSV I linked in post # 18 is a non-OE replacement. You also have to get the Airtex 1P1132 connector to splice into your harness so the FSV works on your van. I'm not sure what FSV Lonewolf uses, that might be a better option if you don't want to do any splicing. I checked and I couldn't find an FSV on the LMC Truck or Dennnis Carpenter website. If you want an OE FSV you might have to check Ebay for a NOS part or ask one of our members (Number Dummy) for the original part number.
Old Jan 31, 2020 | 09:30 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
as explained, you need to change the wire harness connector and cut the back your OEM Plastic fuel lines and use rubber fuel line and clamps to connect it. it is not Plug and Play.
IF you want Plug and Play then search 6C3Z9189A .....
Verify that the electrical connector on your Van Matches those Spade type pins.
Old Jan 31, 2020 | 10:31 AM
Charmalu's Avatar
Charmalu
I used one of these, The market is swamped with these after market one`s probably being massed
produced in China. Look exactly like the OEM Ford valves. uses the same plug in the wiring
harness, and use the same factory push on plastic hose.
Don`t remember if I got it off Amazon or E-bay.
https://www.amazon.com/6C3Z-9189-Selector-Assembly-Ranger-Diesel/dp/B07GVGLM63/ref=pd_sbs_263_2/144-8721894-8846514?_encoding=UTF8&pd_rd_i=B07GVGLM63&pd_rd_r=72f7ee1c-30af-4817-b924-9f9fc95bd97b&pd_rd_w=3qSSx&pd_rd_wg=RO0y5&pf_rd_p=bdd201df-734f-454e-883c-73b0d8ccd4c3&pf_rd_r=3V5GCZ5GSQFN05YMAY5K&psc=1&refRID=3V5GCZ5GSQFN05YMAY5K https://www.amazon.com/6C3Z-9189-Selector-Assembly-Ranger-Diesel/dp/B07GVGLM63/ref=pd_sbs_263_2/144-8721894-8846514?_encoding=UTF8&pd_rd_i=B07GVGLM63&pd_rd_r=72f7ee1c-30af-4817-b924-9f9fc95bd97b&pd_rd_w=3qSSx&pd_rd_wg=RO0y5&pf_rd_p=bdd201df-734f-454e-883c-73b0d8ccd4c3&pf_rd_r=3V5GCZ5GSQFN05YMAY5K&psc=1&refRID=3V5GCZ5GSQFN05YMAY5K
Put this on my 86 6.9. These fit 83 all the way up through the POWER Stroke and maybe beyond.
Charlie
boots6868
Mar 8, 2017 09:46 PM
ToddGatman
Jul 2, 2013 03:43 PM
truckerbear
Feb 6, 2012 11:20 AM
cclc1021
Nov 28, 2006 09:55 PM
ac700wildcat
27
Nov 26, 2006 04:12 PM
