1978 - 1996 Big Bronco
1987 Bronco Prospect
Old Jan 27, 2020 | 12:34 PM
DirtMover38's Avatar
DirtMover38
Exclamation 1987 Bronco Prospect
Looking at purchasing an 87 ford bronco that I came across as a possible daily driver. Has under 115K miles, noted a few issues and wanted to see if I could get ya'lls opinion!? Issue of biggest concern is that the owner says transfer case would not engage 4wd the last drive. He says that it shifts fine and through all gears good, as mentioned just wont engage the 4wd now along with an exhaust leak and steering column needing rebuilding which I'm not to worried about.
I'm not really familiar with the broncos and wanted to gather yalls input if possible on how common of an issue the transfer case is on these vs it typically just being an sensor or linkage adjustment issue. Thank you all in advance for the help!
Old Jan 27, 2020 | 04:51 PM
bluovl's Avatar
bluovl
It all depends on how much?
Old Jan 28, 2020 | 09:19 AM
DirtMover38
Asking 4k, Truck actually has around 300K on body, 50k on rebuilt motor. Body, sheet metal, in really good shape along with interior.
Old Jan 28, 2020 | 12:27 PM
Kemicalburns's Avatar
Kemicalburns
for the issues you list its not worth $4k what motor? what trans? the 4wd issue could be an easy or expensive fix depending on the issue.
just my opinion.
Old Jan 29, 2020 | 01:55 PM
evan_nugget's Avatar
evan_nugget
Definitely not 4K. Post pics if you can get some.
BroncoIIidiot
Bronco II
Aug 28, 2015 10:01 AM
longhorns13
Sep 30, 2009 09:12 PM
alteran
Bronco II
Oct 10, 2007 09:13 AM
76F250HighBoy
Oct 25, 2005 09:08 AM
fordmando
Bronco II
Oct 28, 2002 07:19 PM
