Steering Problem
Old Jan 26, 2020 | 07:29 PM
mlem894's Avatar
mlem894
Steering Problem
Hey guys, I'm chasing a steering problem on my boss's 96 F350. It's a regular cab 4x4 automatic. While driving straight the wheel wobbles slightly back and forth from right to left, and you can feel it pulling instead of just being a typical loose steering shaft. The truck did the same while going through curves and was amplified by a drifting feeling. I found the ball joints on the driver side were trashed so I replaced all four. While doing the ball joints, I found the axle shaft U-Joint on the driver side was trash as well, so I replaced both U-Joints while the axle shafts were out. After replacing the ball joints and U-Joints, the drifting going through curves is gone, but the steering pulling on straight aways is still there.
I checked the tie rod ends and stabilizer and everything is tight and in good condition. I also rotated the tires front to back to check for an unbalanced tire or bent rim (its a work truck), and had no change. The problem is amplified with the hubs locked and in 4x4. Is the steering box itself going bad? Maybe a bearing in the shaft/box?
Thanks guys!
Old Jan 26, 2020 | 08:21 PM
97-psd's Avatar
97-psd
You may need an alignment check. It is always a good idea after front end work
Old Jan 27, 2020 | 06:50 AM
tjc transport's Avatar
tjc transport
i ain't rite
i agree, it sounds like the front end is out of alignment.
Old Jan 27, 2020 | 10:18 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Did you replace the leaf spring bushings and shackle? What about the tie rods? Are the wheel bearings tightened correctly?
All those can cause alignment issues.
bobz71
Mar 6, 2019 08:22 PM
dgsone
May 26, 2012 06:50 PM
scotty31
Apr 27, 2010 12:36 AM
YamakidCR500
1978 - 1996 Big Bronco
Mar 15, 2009 07:20 AM
Jsmooth65
Oct 10, 2008 11:17 AM
