Under Dash wiring harness question
Old Jan 25, 2020 | 11:24 AM
67Fordinprogress's Avatar
67Fordinprogress
\\\\\\\\\\Hey Guys,
I have the 1964 F-100 I am working on the past few months and last night I was removing the wiring harness from under the dash. It was bridle and breaking apart , been cut and so many times it look terrible. I am scared to reuse it when I get to that point. So my question's are the i.d. tag said it is C4TB 14A032 F and I cant find anything on that. I cant seem to find that one. What other wiring harnesses can I use? I see that CG Ford parts has one but is a C4TZ-14401-A. Will that work or will a 63 model work? Dennis Carpenter has them in reproduction for 63 models. Mine was a early build but they are a lot of money to for me to guess at. Or does anyone have a C4TZ-14401-J they would sale me?
Thanks in advance .
Old Jan 26, 2020 | 10:15 AM
jowilker's Avatar
jowilker
You can cut and replace the wiring, one wire at a time. It's 12volt not 220.
John
Old Jan 26, 2020 | 09:59 PM
67Fordinprogress
John
That's most likely what I am going to do. Thanks
Old Jan 26, 2020 | 10:10 PM
Christmas's Avatar
Christmas
It will be a lot easier if you just pull the harness out lay it on a bench and sort it out, replace and repair what's bad or wrong. Your back will thank you.
Old Jan 27, 2020 | 07:49 AM
66v8baby's Avatar
66v8baby
Originally Posted by 67Fordinprogress
\\\\\\\\\\Hey Guys,
Thanks in advance .
The 14401-A is for a 30 amp generator, the 14401-J is for a 42 or 52 amp alternator. I would try to find a good replacement harness rather than try to piece the old one back together, and if I couldn't find one in good enough condition, re-wire it with an aftermarket kit.
Old Jan 30, 2020 | 04:26 PM
67Fordinprogress
ok , Thanks . My truck has an generator so I will try to find that one,
Thanks for the info
superduty4x4
Feb 8, 2020 08:19 PM
69issofine
Jul 3, 2015 08:41 PM
learpilot
Jul 2, 2010 12:10 PM
yetiman
Mar 24, 2009 05:09 PM
1972FordCustom
Mar 14, 2006 01:00 PM
