Fuel Pickup Foot
And I also have an Excursion so that means cutting the skid plate. I don’t see a benefit of a sump on anything but a track truck to be honest. If I was buying a truck and found out it had a sump I would probably pass.
I cancelled my order and have this foot on the way now that I know it will fit! Thanks again.
I should add that never had any intention of using the hose off the sump as a feed. I plugged mine. And yes the factory feed is an atmospheric pressure deal (if you will inside the tank). So extending the pickup into the sump only helps feed naturally.
https://www.xtremediesel.com/beans-d...ine-micro-sump
