Replacement Beds
Old Oct 13, 2003 | 10:03 AM
86rustbucket's Avatar
86rustbucket
Replacement Beds
Does anyone have any ideas on a good reliable source for replacment beds. Looking for a 80-86 8ft bed, styleside.
Old Oct 14, 2003 | 04:23 AM
Bruce MacDonald's Avatar
Bruce MacDonald
Unhappy
I've just been looking into the replacement bed situation myself for my 85 with an 8 footer. In speaking with a autobody guy last weekend, he determined that my bed is way too banged up and rotted. His recommendation was to go to a junkyard. He said he believes that the beds for the 80 to 87 styles are compatable with those on the syles up to 97. If this is the case, it's alot easier to find a bed in much better condition. Good Luck!
Old Oct 14, 2003 | 04:30 AM
RabidJade's Avatar
RabidJade
I seen it done but the body lines don't line up exactly. I noticed it before I became a Ford truck fan so its noticable to the normal person. But, if it works, then you can't go wrong.
Old Oct 14, 2003 | 11:49 AM
ShaneSyma's Avatar
ShaneSyma
I got my new bed for $100 at a truck salvage yard. Its a 87-96 Bed but I don't care if the body lines match. I'd go to the local salvage or junkyard and look.
Old Oct 14, 2003 | 12:57 PM
andym's Avatar
andym
http://www.rustfreeparts.com/
Old Oct 14, 2003 | 01:58 PM
Txquadhunter24's Avatar
Txquadhunter24
the Diff. in the 87 up Beds isn't the body lines. It's the wheel well openings are diff. If ya don't look at em real closde ya can't tell. If you want it to really match do a frontend swap. Most do the frontend swap from 93 up since they got a better looking frontend then the real boxy shape of the 87 to 92 fronts. If you pull the frontend in tact with the core support it's a easy bolt on swap. only trouble is fabing up bumper brackets for the newer style bumpers.
Old Oct 14, 2003 | 04:51 PM
bremen242's Avatar
bremen242
If you are really concerned, found an 87+ bed with semi-rotted wheel arches. go buy the cheaper 80-86 complete wheel arches from motorhaven, and have your body man weld them up.
