New member
. My name is Brian Kanouff..I need some help. I got new ford clutch slave cylinder . Concentric 91 f_150 4×4. The Mazda transmission 5 speed the line going in had a clip to hold it. But theres no place for a clip in the new cylinder will it lock in? And how does it come out if need be
As this is an intro section, you will not get much help with your problem. But, if you ask your question in the Older, Classic and Antique section, you may well receive several responses and lots of help.
Yeah, what pbsdaddy said ^^^^^^^ , the "1987 - 1996 F150 & Larger F-Series Trucks" forum would be your best bet. Also, I think pictures of old and new would help when you post over there.
