Error Code when updating Sync3
Old Jan 23, 2020 | 12:54 AM
upanddownau's Avatar
upanddownau
Angry Error Code when updating Sync3
Have a 2018 F250 Superduty Platinum Diesel with Sync3 ver 2.2 build 16280 and when I start up I get an error message : Installation Failed LST_ERR05 download files again and contact a number -which is useless to me as I'm in Australia.
I have tried to upload files on USB stick as instructed.to get the updated Sync3 ver 3 .Now When I start up and insert the USB stick I now get a message Installation Failed error code SIGN_ERR01 and the USB isn't recognised.
Have changed the USB to a music USB and that gets recognised ok but as soon as I insert the USB with the Sync 3 update files I lose the USB. (can only see the radio and CD on the screen).
have tried 5 different USB sticks that work in other vehicles and as soon as I insert them with the update files same problem occurs. The number to contact shows as 610-386-133673, but when i previously tried to get information from Ford they told me to contact a local dealer in Australia and the local dealers know SFA and the company that converted the vehicle to RHD are limited and suggest I don't upgrade as I may have a sat nav map issue - original maps were US based and as useful as a Trump Tweet and had installed an Aus version of the maps which work fine. Ford Australia handball to Dealers who know nothing about US produced vehicles and not interested in following up and suggest I contact Ford Australia (These blokes must have worked for government departments prior to the motor industry?) Is Sync 3 ver 3 worth the trouble or is there some way the vehicle will read the USB stick with the downloaded files?
Old Jan 23, 2020 | 01:58 AM
AK350's Avatar
AK350
I just updated my USA 2018 F350 yesterday.
My only suggestion is are you formatting the USB stick as "exFAT" before you put the files on it?
I have no idea what exFAT means, but that is one thing the Ford instructions specified.
Rich
Old Jan 23, 2020 | 03:28 PM
upanddownau
Angry Sync3 update
Rich,
Thanks for that and yes I formatted the USB stick(s) exfat32 - windows format even with a few verbal instructions to the said USB sticks, still no joy
Old Jan 25, 2020 | 09:49 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Originally Posted by upanddownau
Rich,
sounds like the files became corrupt somehow
shoot me a PM with your IVSU package numbers and I will see if I have them to link for you
Old Jan 26, 2020 | 04:41 AM
hollygreenman's Avatar
hollygreenman
I went to site for free download of update and it advised me to use thumb drive with at least 15 GB of space. So, I got a new USB thumb drive with 32GB just to be sure. When I tried to download 15 GB file to 32GB thumb drive, I'd get the message that the file was too large for the capacity I had. Wtf?!
So, upon further research, I discovered that a thumb drive formatted in fat32 was only capable of accepting files up to 4GB at a time. So, I re-formatted thumb drive in NTSF and then had no problem.
So, be sure the entire file is downloaded to thumb drive.
Good luck.
Old Jan 26, 2020 | 03:32 PM
kper05's Avatar
kper05
After downloading and to easily test the integrity of the compressed file, attempt to extract (unzip) with the default Windows 10 "extract all" option or use 7zip. If one or more of the other compressed files error during unzip, the file likely became corrupt during download.
I was having issues with two files after multiple downloads from the Ford owner site. 7zip would error during extract and I could not manually copy these files to a local SSD or USB using Windows explorer. The other files were fine.
\JR3T-14G381-AS.zip\SyncMyRide\JR3T-14G381-AS.tar.gz
\JR3T-14G381-AS.zip\SyncMyRide\JR3T-14G391-CE.tar.gz
While I don't have issues downloading files, I have issues downloading JR3T-14G381-AS.zip from Ford. So, I then connected my laptop to my Verizon mobile hotspot (no traffic inspection) and downloaded the same file without an issue. I am able to extract JR3T-14G381-AS.zip without errors and I can copy the two above .gz files manually as well (to test). Traffic inspection on my network firewall is likely causing this grief.
I'm using a 16 GB Corsair Slider X2 formatted to exFAT with 32 KB allocation size, unchecked quick format. A full format doesn't take too long with USB 3.0. I copied the extracted "SyncMyRide" folder and the two files, "autoinstall.lst" and "DONTINDX.MSA" plus the original zip file (JR3T-14G381-AS.zip) to the root of the USB drive. It's what I did last time and it updated without an issue. Total space used is 2.95 GB for this update file.
Instead of running the engine, I connect a battery charger (be mindful of the BMS if it exists) and update in KOEO. Insert USB drive to a front USB port, KOEO, waited for the update to download, cycled KOEO when instructed and it reported updated. I then uploaded the sync*.xml file in \SyncMyRide\ that gets created prior to key cycle. I don't think I reported the XML last time, did so this time for the heck of it.
Disclaimer: I have the non-sync basic radio in my truck. This was my 2017 Fusion with NAV so the file name may be different for F-series. However, it's Sync 3 so this process is the same.
ddown54
Jun 15, 2019 04:40 AM
bkuuz1
6.7L Power Stroke Diesel
Dec 14, 2016 06:18 AM
E99Mike
Feb 15, 2013 12:49 PM
ssharber
Jan 17, 2008 07:15 PM
Supercab
Jan 22, 2004 09:49 PM
