Does Forscan read baro?
1000 it is good. 1100 to 1500 shakes and smokes.
Most of the smoking is in 1200-1300 rpm range.
Injectors were replaced about 15k miles ago.
Remans from Swamps, they came with O rings.
The truck has a non ebpv ped, and valve delete.
There is no tuner, I believe the tuning is stock.
I have replaced with ford parts, IPR, ICP, MAP, EBPS. The tube running from the manifold to the sensor is new. The glow plugs are new.
It has a elch cps from Napa. Tank mods and fuel pressure is a little high 70 psi. After looking at threads I can not verify the difference between readings from MAP, EBPS and Baro. Forscan is reading baro as 0.0 or 1.$ I saw another post where
someone had the same issue but no mention if it was Forscan or the pcm. I am using the laptop version.
The oil level on the stick is at the middle of the gauge. It is T6
Now that the temps outside have dropped I am getting white smoke on start up.
I ohm the glow plugs through the UVCH. They test good. It has a stancore relay that is working.
Thanks in advance
