PROBLEMS AT IDLE
Old Oct 29, 2000 | 10:29 AM
67ccougar's Avatar
67ccougar
PROBLEMS AT IDLE
I got a 90 F-150, 300 I-6 5 speed with 191,000 miles, she's run good for many years, but recently started having idle problems. It will start good and idle good for a while, then it starts sputtering and missing. I hooked up a timing light, and that thing is jumping all over the place. It will spend about five seconds jumping around about 10-12 degrees BTDC, then it will jump about to 20 BTDC. When it does this, it sputters, then it returns to 10-12 again. Also it will cout out for a split second after a long hard pull, I don't know if that is related or not. Any help is appreciated.
Old Oct 29, 2000 | 01:30 PM
PAUL_2's Avatar
PAUL_2
PROBLEMS AT IDLE
When you check the timing , you have to remove the Spout Connector , are you removing it when you check the timing ? When was the last time you changed the regular maintenance items ? Cleaning the throttle plates & Idle speed control may help .
Old Mar 4, 2001 | 08:48 PM
mtfl's Avatar
mtfl
PROBLEMS AT IDLE
[font size="1" color="#FF0000"]LAST EDITED ON 04-Mar-01 AT 09:50 PM (EST)[/font][p]I have an 1990 F150 I'm having the same exact problems .I replaced the EGR valve that wasnt it ,plugs and wires that wasnt it egr sensor that wasnt it whats next any help greatly appreciated.thanks mike
Old Mar 4, 2001 | 10:59 PM
whiteboyslo's Avatar
whiteboyslo
PROBLEMS AT IDLE
My buddy has an 1989 f150 with a 5.0, and his was giving him a very similar problem. we replced the egr, the wires, the plugs, same thing. turned out it was the fuel pressure regulator if i remember right. he's on this message board so i'm sure he'll jump on and correct me if i'm wrong. hope that helps.
Old Mar 5, 2001 | 08:30 PM
mtfl's Avatar
mtfl
PROBLEMS AT IDLE
Thanks for your input,I'll have too check it out.
Old Mar 6, 2001 | 07:27 AM
TallPaul's Avatar
TallPaul
PROBLEMS AT IDLE
