Break in Before towing
Old Jan 17, 2020 | 01:59 PM
SpencerPJ's Avatar
SpencerPJ
So, I'm looking for a 2018+, F250 Lariat, 6.2 gasser. The options and combinations I hope for might require me to order a new one. That's okay with me, but looking at some posts, they take 3 months to get in. That's okay too I guess, but I have a 6000# travel Trailer I might use in mid-May for the weekend, couple hundred miles round trip, pretty flatland, and if I don't get it until early May, I might only have a few hundred miles on it. Given that this is not a huge load, would that be acceptable? Some say 500 miles, some say 1000 miles, some start towing the day they get it. Your opinion? (I can't find in the Ford online manual either)
Old Jan 17, 2020 | 02:22 PM
jschira's Avatar
jschira
From the page 313 of the 2020 F-250 Owner's Manual:
BREAKING-IN You need to break in new tires for approximately 300 mi (480 km). During this time, your vehicle may exhibit some unusual driving characteristics. Avoid driving too fast during the first 1,000 mi (1,600 km). Vary your speed frequently and change up through the gears early. Do not labor the engine. Drive your new vehicle at least 1,000 mi (1,600 km) before towing a trailer. Make sure you use the specified engine oil. See Capacities and Specifications (page 442). Do not add friction modifier compounds or special break-in oils during the first few thousand miles (kilometers) of operation. These additives may prevent piston ring seating.
The best explanation that I have read for the 1000 miles is to allow the gear teeth in the diff to wear in. Overheating the teeth prior to wearing in can create hard spots and reduce longevity.
Makes sense to me, but I do not know if it is true.
As to whether you follow the manual or not, that is up to you. Many on this board think that the Ford engineers are idiots and don't know what they are talking about.
Old Jan 17, 2020 | 02:51 PM
Fordplatty15's Avatar
Fordplatty15
You will get 2 answers, follow Fords requirement or dont.
It's up to you to choose.
Old Jan 17, 2020 | 03:38 PM
Lamoon78's Avatar
Lamoon78
I always have done the 1,000 miles before towing and never have any issues.
Old Jan 17, 2020 | 04:03 PM
crewzer's Avatar
crewzer
Smile
In addition to breaking in the drivetrain and the tires, this period helps break in the brake pads, allows a time to get through new product “infant mortality” and develop some reliability confidence, and also provides a honeymoon period for the driver to get to know his/her new vehicle.
HTH,
Jim / crewzer
Old Jan 17, 2020 | 04:10 PM
SARDiverDan's Avatar
SARDiverDan
I did not pull with my 6.7 in the first 1,000 miles. I am sure some are pulling with their trucks the second day of ownership but I will stick with the Ford recommendation on this issue. I had someone telling me that you need to take it out as soon as you buy it and run it with a heavy trailer up the steepest incline you can fine to help break it in right an if you don't, you will have nothing but issues later on. Again, the world is full of advice on what "you should do" but you need to make that decision for yourself.
Old Jan 17, 2020 | 04:27 PM
Desert Don's Avatar
Desert Don
Isn’t this question worn out yet??? Sheesh!!! LOL
Old Jan 17, 2020 | 04:28 PM
yardbird's Avatar
yardbird
There seems to be quite a few people on here looking to sell their trucks. Maybe you can find one of those. It seems most are just wanting to trade for a new one, so you may get a decent deal.
Old Jan 17, 2020 | 05:05 PM
Snowman 8's Avatar
Snowman 8
Just hookup and GO! The owners manual says blah blah blah drive it 1000 miles first. I’ve never done that with any of my trucks. F150 or F350. Never had a problem with drivetrain either. I don’t have a choice with my F350’s, they are work trucks. It’s only purpose is to pull trailers and haul tools, I’m not going to take a weekend to drive 1000 miles so I can hookup to a trailer and go to work on Monday morning. Besides, the 6000lbs that you are talking about isn’t much of a load anyway.
Old Jan 17, 2020 | 06:46 PM
C12H24's Avatar
C12H24
No. It will continue to cycle about once a month. Now if we could divert the path of this to an oil thread, life will be perfect.
Would you do a heavy pull with the factory fill of 10W-30 oil?
Old Jan 17, 2020 | 07:58 PM
DSLTRK60's Avatar
DSLTRK60
Both the Dana sourced and Ford Sterling axles are equipped with lapped gearsets.
​​​​​There isn't a reason to worry about the rear axle break-in for 'light' loads like the op mentioned.
I would be easy on the engine in regards to high rpms until the rings seat.
The transmission is nothing but planetaries in series, not much to worry about there.
Old Jan 17, 2020 | 08:07 PM
DSLTRK60's Avatar
DSLTRK60
Boom. This right here.
Old Jan 18, 2020 | 06:08 AM
jschira's Avatar
jschira
You are prophetic. Go buy a lottery ticket.
Old Jan 18, 2020 | 08:06 AM
Fordplatty15
Nah, I do not gamble.
Old Jan 18, 2020 | 08:21 AM
brialin's Avatar
brialin
Never broke one in yet. Just run it. I have bought new Macks and Peterbilts over the years and just ran them. What was I supposed to do, run around empty for the first 1000 miles?
