Drum brake self adjuster??
Old Oct 12, 2003 | 09:54 PM
MuchToMyDelight's Avatar
MuchToMyDelight
When I hit the brakes just hard enough not to actually stop the truck, I get a rather loud clunk from my driver side front tire. Best I can figure is that the shoes are adjusted in too far and the pressure from the pedal kicks it out enough to clunk. I am going to pull it apart tomorrow, and have a look-see. I was just wondering if anyone has had any experiance with this type problem. The PO rebuilt the brakes-(rebuilt cylinders, new springs, etc) and put on new brake shoes about a year ago.
Old Oct 12, 2003 | 11:17 PM
Faithful Old Road Dog's Avatar
Are you sure it's not suspension noises?
Old Oct 13, 2003 | 01:45 PM
rebocardo's Avatar
rebocardo
Clunks are usually not brakes unless you have rotors and the keys are worn. I would look at worn radius arm bushings, shocks, or the track arm. Bad ball joints too, though with those you would most likely have really vague steering if they were far enough gone to clunk.
Old Oct 13, 2003 | 05:02 PM
MuchToMyDelight
It doesnt do it when I down shift and let the engine brake, only when I lightly tap the brakes, even when it is just sitting.
Old Oct 13, 2003 | 05:38 PM
user 5363849's Avatar
user 5363849
Engine braking only affects the rear axle, not the front. (not a 4x4, right?)
Old Oct 13, 2003 | 08:08 PM
baitmaster's Avatar
baitmaster
clunky things
I had that noise once. Turned out to be worn out rubber bushings on tracking arms (?). Braces that run from frame to front axle. (4X4) Hitting brakes would shift axle to rear and bottom out bushings.
Old Oct 13, 2003 | 10:48 PM
MuchToMyDelight
It is 2x4, i was just saying that it doesnt do it when it "nose dives" from the engine braking, it doesnt make the noise. I am 93.745532% sure its in my brakes. I'll pull them off tomorrow and look for sure. It stops straight most of the time, but will ****** to the left a little if you slam the brakes really quick.
