Carli Question
Old Jan 13, 2020 | 09:45 AM
Shreve T's Avatar
Shreve T
Carli Question
Question: Those of you who have Carli, Can or did you notice a big improvement by adding there radius arms ?
Old Jan 13, 2020 | 08:01 PM
FDNYL136's Avatar
FDNYL136
Radius arms
I don’t have Carli but I do have pmf 3 link and am very happy with the results.I originally used the caster bushings but didn’t like the way the ball joint angle was.
Old Jan 13, 2020 | 08:44 PM
ymsmiley's Avatar
ymsmiley
I had everything installed at the same time, so hard to say. But if, for ex, you only put on Carli RAs I doubt you'd notice some major ride change. They are better quality than stock but are more to help correct geometry and they're also a little narrower for a bit more tire clearance. But complete with the whole Pintop level kit? Hell yeah it's an improvement!!
Old Jan 14, 2020 | 04:25 AM
allendks45's Avatar
allendks45
Just had the full pintop installed last week. I knew the moment I left the installer shop I made the right choice. Now I can't wait for the snow to melt and run it out in the Backcountry. You might not need them since it's an option from Carli but I figured I'm already spending the coin. Better to have the fully engineered system working.
Old Jan 14, 2020 | 07:06 AM
Shreve T's Avatar
Shreve T
I have the full 4.5 Back Country Carli lift, Just unsure of the RA just yet..
Old Jan 14, 2020 | 07:44 AM
honda250xtitan's Avatar
honda250xtitan
if it was me, id get the torsion sway bar instead of the RA's.
Old Jan 14, 2020 | 07:51 AM
BocaIvan's Avatar
BocaIvan
If you don't have the RAs are you just using caster shims to correct the alignment?
Old Jan 17, 2020 | 11:18 AM
tothe birds-a's Avatar
tothe birds-a
Carli Radius Arms sure look nice but they are not adjustable. Can not justify that kind of money and be able to install a PMF Radius Arm 3 Link and be able to actually fine tune axle rotation for coil spring alignment and also provide caster alignment. Almost purchased the Carli Radius Arms to resolve a front coil spring "bow" with their Back Country System. After some research and good advice from this forum, no guarentee that the Carli Radius Arms would resolve issue. Must admitt that CJC Offroad and others said that the coil spring "bow" did not cause any problems. Just looks like crap. I'm going with PMF Radius Arms
Old Jan 17, 2020 | 11:21 AM
Section179's Avatar
Section179
Every thread needs pics, so here are some of my PMF radius arms.
Old Jan 17, 2020 | 11:33 AM
Shreve T's Avatar
Shreve T
Think i'm going to go with both RA and Torsion sway bar since i have everything else Carli
Old Jan 17, 2020 | 04:57 PM
wicked 2018's Avatar
wicked 2018
I went with Lewis built. Very stout, adjustable and clears 37"s on a 2.5" lift.
Home
Old Jan 18, 2020 | 01:45 AM
SBC's Avatar
SBC
Just curious approximately what you guys are paying for the Carli 4.5 Pintop? With labor, radius arms, king shocks and the full package. I am being quoted around 12k which seems crazy. Wondering if that is normal and if it could possibly be worth that much cash.
Old Jan 18, 2020 | 07:58 AM
honda250xtitan
install it yourself.
go backcountry shocks if you want the smoothest road ride
Old Jun 3, 2020 | 12:12 PM
paydirt's Avatar
paydirt
I like the idea of an adjustable arm, I just have no clue how I would know how to correctly set them. Do you make adjustments then go get the caster checked by a shop? Sorry if this a stupid question. Just trying to learn.
Old Jun 3, 2020 | 08:25 PM
0835064's Avatar
0835064
Install it yourself. I have everything they offer for the 2.5, custom remote airbag system, have rebuilt and powder coated the king shocks, and have gone thru 2 sets of tires and I don’t have 12k into it.
pintop with radius arms, sway bar
