2005 excursion ceiling panel display
Old Jan 11, 2020 | 10:38 AM
Emittim3's Avatar
Emittim3
I have a 2005 limited and the ceiling display that should show mileage and compass isn't working (never worked for second owner, I am the third owner). I'd like to try and fix it. Anyone have instructions on how to pop the thing out without damaging it?
Old Jan 11, 2020 | 10:48 AM
WE3ZS's Avatar
WE3ZS
Have you read the Tech Folder thread on this repair? I think it should walk you right through the entire process.
Good luck and be sure to report your results!
Old Jan 11, 2020 | 11:04 AM
pirate4x4_camo's Avatar
pirate4x4_camo
crack it open. find the resistors that have fallen off or the solder joint is cracked.
use a solder wick to desolder the resistor and board and the re-solder the resistor back in place.
it is a easy task if you know how to solder correctly and likely a huge frustration if not.
also several people/companies do it for about $20 bucks. check ebay for starters
Old Jan 11, 2020 | 03:40 PM
ShelbyHauler's Avatar
ShelbyHauler
If you have used a soldering iron before, sometimes you can just heat up the solder around the resistors on the circuit board to fix a cold solder joint. If not, farm it out to someone who knows as you can mess things up.
Old Jan 11, 2020 | 04:18 PM
Emittim3's Avatar
Emittim3
Looking for the tech thread on the repait but not finding it yet. Got a link?
Old Jan 11, 2020 | 04:28 PM
mrshirls's Avatar
mrshirls
Trailering
https://www.ford-trucks.com/forums/4...ml#post3266008
I just put a bit more solder on mine. If you are reasonably handy, just take it apart and solder the black things back down again. Good luck.
tech threads here: https://www.ford-trucks.com/forums/1...excursion.html
Old Jan 11, 2020 | 09:46 PM
RoberDen's Avatar
RoberDen
I also have a 2005 and repaired my non-working display with help from the threads in the tech folder. Not difficult but your soldering skills are the key. There are several YouTube videos on subject that are worth watching before you jump in. One thing not to forget in the 05 (with a full overhead shell as in the Limited) is to first remove the screw in the sunglasses compartment and then pull the shell down from the front (first).
Old Jan 18, 2020 | 08:17 AM
TrevinE's Avatar
TrevinE
Ditto on the resistors. I just did mine. It was one of the 620s. It had not fallen off and there was no burnt marks. At first glance, everything looked fine but I took a pick and fiddle with each of them. Sure enough, one of them had come unsoldered on one end. Easy fix.
Old Jan 18, 2020 | 10:47 PM
P G's Avatar
P G
Ebay, there's a guy in sflorida, you send the old one in and get a rebuilt. I've done it 2x on my 05.
Old Jan 19, 2020 | 04:34 AM
Mike Maddaluna's Avatar
Mike Maddaluna
If your good with soldering..There Are Videos on how to ..But if ya not there are places that rebuild them..My up top always shows -40 but my Climate control shows the correct out temp? I think theres more one sensor...But ya can get them rebuilt ..2005 limited too....
Old Jan 19, 2020 | 04:36 AM
Mike Maddaluna
Mine is reading -40 always but the Climate Cluster shows correct outside temp ?05 limited do we have 2 seperate Temp sensors ..i think theres one in on dash .one in front rad grill black sensor?
Old Jan 31, 2020 | 07:27 PM
ExcursionPorschePuller's Avatar
There is a youtube video on how to do this, to include console removal to soldering the resistor. I followed and fixed mine.
The "middle" 680 ohm resister was discolored. I heated ends with low temp soldering iron and dabbed just a bit of solder. Worked like a champ. Did the same with my daughter's Corolla digital clock years ago and fixed it. With it, I didn't even add solder. Might not need to here either. Went from extremely dim to working well.
Old Jan 31, 2020 | 07:39 PM
RoberDen's Avatar
RoberDen
Mine is a 2005 Limited. The shell is different. It has the map lights at the rear end of the console. There is a screw in the sun glass compartment that has to be removed first. Then you pull down the shell from the front first (there are two clips) and then you slide forward just a bit and pull down the rear (one clip as I recall but two tabs that go in slots). There are three wire harnesses that you unplug and then it is completely separated from the EX.
Old Jan 31, 2020 | 07:53 PM
My console sounds similar, if not same as yours. Somebody had previously removed the console and broke the screw hole in the glasses compartment to which you refer. Guess they missed it. I was able to remedy with a new screw and a washer to cover the hole. Guess I got lucky. I had wondered why there was a slight gap between the ceiling and console. The console in video might be different, but I suspect the circuit board and fix is the same. Alternatively, Amazon sells a replacement board for a mere $212!!
Old Jan 31, 2020 | 08:16 PM
RoberDen's Avatar
RoberDen
Console in the video does not have map lights. If yours does, then it is like mine. In the video, the console is two pieces, an outer shell and than another one inside holding the components. In the console with the map lights it is all one piece. Just disconnect the wire harnesses and it can be completely removed. Take in the house and work on it.
The computer module is held in place by a couple screws. Remove the module and you can put the shell back until you get the module repaired. Easiest way (if you are not handy soldering) is just to send it to the guy in Florida that has the ad in eBay (I think there is a reference somewhere in this thread, if not let me know and I will search for it).
