Sponsored by: Auxito
Clunking from rear
Old Nov 28, 2003 | 11:11 AM
Renegadesrun's Avatar
Renegadesrun
I love this place!!! I have this problem as well! Having problems isnt what bugs me. It happens.
Having a undiagnosed problem really,..... reeeaaaally, bothers me.
Old Nov 29, 2003 | 05:39 PM
99f250notsd's Avatar
99f250notsd
thanks for the info, same noise and symptoms so what is the best grease to use the ford teflon or another?
Old Nov 30, 2003 | 10:49 AM
z 97ford1's Avatar
z 97ford1
I use the ford teflon and it takes care of the problem but, I have to do this about every six months because the splines will become "dry" again.
Old Sep 25, 2004 | 10:04 PM
boydstun's Avatar
boydstun
I finally got around to doing this fix. Works like a champ
Old Sep 26, 2004 | 10:38 AM
goonski's Avatar
goonski
I had the same noise on my 03 screw 4x4 and took it into the dealer as it is still under warrenty and the tech told me that in some pickups, when the rearends were assembled from the factory that they are suppoesed to put in a additive for the gear oil in the diff and not enough was put in. As a result it prematurely wears out the clutches for the limited slip. The dealer replaced the clutches and put in the proper amount of additive and gear lube and problem is gone. The noise on my truck would be when you started at the light or turned a hard right or left. I hope this helps as this was a more perminent fix.
Old Sep 29, 2004 | 01:55 AM
vanj's Avatar
vanj
Have the same problem with the 88.
Thanks for the info.
