Injection Pump wiring diagram
Old Jan 8, 2020 | 04:36 PM
6.9lbluenose's Avatar
6.9lbluenose
Does anyone have a diagram for an 1984 6.9l that shows how the key connects to the fss. Timing advance and fast idle. Specifically interested in the fss
Old Jan 8, 2020 | 06:29 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I've posted this before several times ...
Old Jan 8, 2020 | 06:42 PM
6.9lbluenose
Exactly what I needed. Thank you
Old Jan 9, 2020 | 07:23 AM
Olds64's Avatar
Olds64
12V IGNition is all the FSS needs to let the IP run. Can't be much simpler than that.
Don't need no stinkin' HPOP or FICM!
Old Jan 9, 2020 | 10:07 AM
6.9lbluenose
Exactly why I choose this truck and engine. Basic and simple to fix while out in the bush. I’m wiring the fss to a backup toggle in case there is ever a wiring issue I can hit the toggle and jump the starter solenoid/or push start the truck. I’m trying to think up an emergency bypass to the fss. FYI I have a emergency fuel shutoff in a ball valve on the main fuel line in case of run away issues
fordnut forever
21
Jan 25, 2012 10:25 PM
dirtynorth49
Nov 12, 2011 02:48 PM
case310350
Jan 12, 2011 08:25 PM
mando jake
Jan 12, 2009 04:59 PM
w5kgt
Electrical Systems/Wiring
Aug 30, 2007 10:53 PM
