I ordered my 2020 SD with the optional "Console Vault" as a $300.00 option and it is well worth the money!!!! Lots of room and a great place to store valuables when you have to leave your truck! Here is a link below to the manufacture and the front page is exactly what it looks like! Great quality and fit!!!! Anyone else order one?
Thanks for that info!! I just ordered one for my 19 using my fordpass points! Should have it In a few days. FYI i had 75,000 points, had enough for the vault and one oil filter. Wanted to use them before they expired.
Anyway, I was worried about that vault taking up too much room, or being too big. I like the little sliding tray but I hear that won't work anymore with the vault installed....
The Four Code......This is NOT the place to store your primary CCW as you could never get to it when you need it. I use the vault as a place to store my CCW when I cannot carry in a place.
I got the locker down with the electronic lock for my 2019. As it was not a included option on my truck.
Back in October, one of the first things I did. Locker down extreme
I’m about to order a lockerdown as soon as I can verify it works with the 2020s. I like it better than the factory unit as it has a larger opening (from everything I’ve seen) and my medkit should fit in the bigger door.
Ok I have to ask: Is the "Lock-er Down" not even a complete safe? As in not even a complete box or am I missing something? And it seems to cost more than the console vault?
None of them are a “full” box as you think of a traditional safe or it wouldn’t be able to be installed.
FYI, the Lock'r Down isn't what should be considered almost as good as the Ford offering. I did alot of research on the "vaults" when I purchased mine, the Lock'r Down Extreme uses 10ga steel, the ConsoleVault uses 12ga. The door is much larger on the Lock'r Down. I also preferred the 4 number lock on n the Lock'r Down.
