Auto lock
Old Jan 7, 2020 | 07:46 AM
roadrunner01's Avatar
roadrunner01
Auto lock
We recently purchased a new 2019 F150 with the 3.0 at the same time my dad did also. Has Ford eliminated the option to turn off the auto lock function like earlier models? It’s driving my dad nuts, as I told him don’t worry I turned it off on my other trucks (‘15 & ‘16). I can’t find it in either the owners manual or within the menu on the dash.
Old Jan 7, 2020 | 08:43 AM
Robbgt's Avatar
Robbgt
I found this option was missing from my 2018 as well. Needed to modify a register in Forscan to return it to the menu. If you're familiar with Forscan, it's an easy change. Register values below depending on trim:
Old Jan 7, 2020 | 08:58 AM
roadrunner01
Thanks for the info, unfortunately I’m not familiar with forscan
Old Jan 7, 2020 | 09:06 AM
Robbgt's Avatar
Robbgt
If you have a good relationship with the dealer, they might be able to enable it for you at no cost. Might go that route first.
Forscan is software that will allow you to connect to your truck with a windows laptop using an adapter and modify programming. It's not overly complicated but you do need an adapter. I used this one:
Amazon Amazon
There is an FAQ writeup available HERE if you're interested in giving it a try.
fordman19762003
Aug 26, 2019 06:25 PM
SeaCarr
Sep 16, 2017 11:20 PM
speed
Large Truck
Jan 20, 2016 11:11 PM
Wildcat Fan
Jan 4, 2011 08:06 PM
