Throttle Bodies
Old Jan 6, 2020 | 09:05 PM
Jonathan White's Avatar
Jonathan White
Throttle Bodies
Has anyone tried to fit up an aftermarket throttle for a 5.0 5.8 bottle to a 4.9
Old Jan 6, 2020 | 11:35 PM
Conanski's Avatar
Conanski
The stock 5.0/5.8 TB is larger than the 4.9 version.
Old Jan 7, 2020 | 08:04 AM
torq'ta 5 8's Avatar
torq'ta 5 8
the stock 4.9 throttle body is 43-44mm, the stock 5.0/5.8 throttle body is 50-51mm, would have to make brackets and other pieces to get it to work, that is a big jump in size, you might get it to idle right, and a BBK 56/61mm would give you major headaches trying to get it to ever idle, you could try porting your intake, before going to bigger throttle body
Old Jan 7, 2020 | 07:05 PM
Jonathan White
idle
after the Maf swap I may try a stock 5.0 throttle body
captain1997
Oct 1, 2011 11:34 AM
mac_91
1978 - 1996 Big Bronco
Nov 28, 2008 02:24 PM
speedracer54729
Apr 22, 2008 02:53 PM
shuttlevalve
May 31, 2007 11:06 PM
choochoof150
Oct 9, 2006 12:31 AM
