Door Lock Actuator
Old Jan 6, 2020 | 05:20 PM
2006E350's Avatar
2006E350
4wd Low
Door Lock Actuator
I have a 2006 E350 are all the doors the same model actuator or are they different.
Thanks
Old Jan 7, 2020 | 04:01 AM
JWA's Avatar
JWA
They will be different if you're asking whether the left front would also fit the side or rear doors then no they're not the same. The actual actuator body will be the same but the rods attaching them to the door latch will be different according to which door you're working with.
Also around 2000 to 2002 the electrical wiring harness connector changed so they are year-specific in that regard as well..
Derek1234
2009 - 2014 F150
Sep 4, 2015 12:53 AM
Silverdawg
Dec 7, 2010 04:22 PM
TJ Shaw
13
Feb 27, 2009 07:58 PM
